FPGA Intellectual Property
6672 Discussions
help:DDR2 can't init done
Hello ,
I want to use the MT47H32M16HR-25(D9KHQ DDR2),but I can't find the it in the " Mega Wizard -- > DDR2 SDRAM Control and ALTMPHY ",
I use the "MT47H32M16CC - 3" ,and repair the parameter ,but the signal(local_init_done) is low.how can i do ?
where can i find the example of DDR2(MT47H32M16HR-25)?
Disable Calibration in Megawizard window
thank you !
but I can't understand,
Can you simulate your design? Archive your project and send to bekrenyov@mail.ru
thank you :
I use modelsim to simulate DDR2 - core,it is sucessful .
I think it is error by configuration IC parameter or PCB hardware
May be two reasons of init failure: calibration failure or invalid parameters loaded into DDR registers. If you disable calibration you can determine which problem you have.
thank you!
I do ,but I can't understand what 's wrong :
I have a demo hardware of "EP3C120", the project can run sucessfully.it include DDR2 ,PLL and something else.
but I use the new hardware "EP3C40F484" ,it is failed .
so it is difficulty to find what happen
only change the FPGA and PCB
hi:
I find the DDR2 core"cs_n,ras_n,cas_n" is always low .but the sucessful porject is pulse .
Check clocks
when I use signaltop capture the clock it is low,but use oscilloscope it is right"192Mhz"
Which frequency do you use for SignalTap? You can't see clock which have greater frequency than SignalTap clk
I use 250 Mhz,can't capture cas_n,ras_n,and cs_n,clk.
--- Quote Start ---
--- Quote End ---
Hi!
Is the calibration only for simulation?
