FPGA Intellectual Property
6421 Discussions
oneAPI MVDR Beamforming Sample
colinz
This sample uses IO Pipes and UDP. If I want to run this sample in an Agilex FPGA card, does that mean the FPGA need to have Ethernet and TCP/IP ip core?
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/C%2B%2BSYCL_FPGA/ReferenceDesigns/mvdr_beamforming#build-and-run-the-design-using-real-io-pipes
BoonBengT_Intel
Hi @colinz,
Thank you for posting in Intel community forum and hope all is well.
Based on the document would assump that you are running the fill system compilation, and for that the BSP that you would be included would have the required IP added accordingly.
Please let me know if I misunderstood the situation.
Best Wishes
BB
BoonBengT_Intel
Hi @colinz,
Best Wishes
BB
BoonBengT_Intel
Hi @colinz,
Good to know that we managed to clarify your doubts, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
