IP: UniPHY with DDR2 controller
Quartus Prime Standard 18.0
Simulation: Nios 2 + Uniphy + Micron DDR2 (MT47H128M16)
Modelsim-intel is used.
Problem: it stops during ddr2 initialization phase. It seems Uniphy IP doesn't follow Micron DDR2 initialization spec. I don't there is 200us which was required by datasheet.
Hi Xiaoqiang Shen,
UniPHY simulation does not adhere to the initialization timing to speed up the simulation so it will fail when using the Micron memory model. I assume the simulation passes with the DDR2 example design with Intel generated memory model. As a workaround, you can comment out the initialization time check in the Micron memory model.
Hope this helps.
Rashmi
Hi Xiaoqiang Shen,
Thank you for submitting the case. Will it be possible for you to share your design files to reproduce the issue at my end and further investigate.
Rashmi
Hi Xiaoqiang Shen,
Hope this helps.
Rashmi
1) Actually it’s defined the tINIT = 200us when launch this UniPHY IP. The parameter is also compliant with Micron datasheet. Why UniPHY IP doesn’t consider it as it knows exact memory parameter.
2) If you look at my first question attachments, you will see UniPHY IP doesn't follow memory initialization sequence. For example: cke should stay 200us when power up.
Unfortunately, UniPHY simulation does not adhere to the initialization timing to speed up the simulation so it will fail when using the Micron memory model.
Which simulation option they have selected. You probably have "skip calibration" selected which is the default.Please change the setting to "full calibration" to get past the error but it will take forever (~4 days) to complete.
I used +define+ALTERA_ALT_MEM_IF_PHY_FAST_SIM_MODEL=0 in related files nios_mem_if_ddr2_emif_0_p0.sv and nios_mem_if_ddr2_emif_0_pll0.sv.
And modelsim shows message: # Using Regular core emif simulation models.
But it still doesn't work.
Does this latest sim run much longer than the previous simulation? It should be running full calibration
Can you please check how long mem_reset is asserted? It should stay low for at least 200usec in full calibration mode
Does this latest sim run much longer than the previous simulation? It should if you are running full calibration
