FPGA Intellectual Property
6670 Discussions
what is the circuit of 2^n -1
these is a problem for me,i need some help.
how can i use verilog describe 2^n -1
the input interface is input[3:0] n;
the output interface is output [15:0] result;
i know can use a table ,but these is some other describe
thanks
i am sorry my english is poor.
if it is just that simple you could write
module MyPower ( clk , In_N , Out_P );
input clk;
input [ 3:0] In_N;
output [15:0] Out_P;
reg [15:0] Out_P;
always @ ( posedge clk )
case ( In_N )
4'd0 : Out_P <= 16'd1;
4'd1 : Out_P <= 16'd2;
4'd2 : Out_P <= 16'd4;
4'd3 : Out_P <= 16'd8;
4'd4 : Out_P <= 16'd16;
4'd5 : Out_P <= 16'd32;
4'd6 : Out_P <= 16'd64;
4'd7 : Out_P <= 16'd128;
4'd8 : Out_P <= 16'd256;
4'd9 : Out_P <= 16'd512;
4'd10 : Out_P <= 16'd1024;
4'd11 : Out_P <= 16'd2048;
4'd12 : Out_P <= 16'd4096;
4'd13 : Out_P <= 16'd8192;
4'd14 : Out_P <= 16'd16384;
4'd15 : Out_P <= 16'd32768;
endcase
endmodule
but you could try to implement some kind of shift functionality
If I understood the question (4 to 16 decoder) then MSchmitt's coding is how I would implement this as well. If you don't want the decoder registered then you would write it like this:
reg [15:0] Out_P;
always @ (In_N)
begin
case (In_N)
4'd0 : Out_P = 16'd1;
4'd1 : Out_P = 16'd2;
4'd2 : Out_P = 16'd4;
4'd3 : Out_P = 16'd8;
4'd4 : Out_P = 16'd16;
4'd5 : Out_P = 16'd32;
4'd6 : Out_P = 16'd64;
4'd7 : Out_P = 16'd128;
4'd8 : Out_P = 16'd256;
4'd9 : Out_P = 16'd512;
4'd10 : Out_P = 16'd1024;
4'd11 : Out_P = 16'd2048;
4'd12 : Out_P = 16'd4096;
4'd13 : Out_P = 16'd8192;
4'd14 : Out_P = 16'd16384;
4'd15 : Out_P = 16'd32768;
endcase
end
First could you clarify? Are you trying to get:
a) (2^n)-1
or
b) 2^(n-1)
I suspect it's a). If not let me know.
module pow_2toN( input n, output result ); wire shift_reg; assign shift_reg = {16'd0,16'hffff} << n; assign result = shift_reg; endmodule
or...
module pow_2toN( input n, output result ); genvar i; generate for(i=0;i<16;i=i+1) begin : result_assigns assign result = (i < n) : 1'b1 : 1'b0; end endgenerate endmodule
or...
module pow_2toN( input n, output reg result ); integer i; always @* begin result = 16'd0; for(i=0;i<16;i=i+1) if(i<n) result = 1'b1; end endmodule
or...
module pow_2toN( input n, output reg result ); integer i; always @* begin result = 16'd1; for(i=1;i<16;i=i+1) if(i<=n) result = {result,1'b0}; result = result + 16'hffff; end endmodule
We could keep going but I digress. I may have some typos in there. What might be entertaining for you is to try all these variants and see what wildly different compilation results they produce.
Jake
Oh Jake great , thats real fun to read and think about.
first example should be
assign shift_reg = {16'd1,16'h0000} << n;
to get the 1,2,4,8,... instead of 0,1,3,7,f,1f,...
It's realy a lesson worth to go through them all and understand them ...
As I stipulated, my assumption was that he wanted (2^n)-1. So the desired result would in fact be (0,1,3,7,f,...). If that assumption is incorrect then all of the examples need tweaking.
Jake
--- Quote Start ---
reg [15:0] Out_P;
always @ (In_N)
begin
case (In_N)
endcase
end
--- Quote End ---
this is also a ROM
can it describe wtih register?
--- Quote Start ---
a) (2^n)-1
or
b) 2^(n-1)
or...
or...
or...
Jake
--- Quote End ---
Hi jakobjones
I am sorry
it is (a)
Is this a RTL description?
Hi jakobjones
I want to know what is the circuit of the description
if you use synplify what above all?
If you have access to synplify, try the various implementations and see what circuits they produce.
Jake
--- Quote Start ---
this is also a ROM
--- Quote End ---
What I wrote wouldn't be synthesized as a ROM (in an Altera FPGA) since it's not synchronous. Instead you'll get the same muxing logic only the result isn't registered. Here is a good doc to take a look at to learn more about HDL coding styles and how they map to the FPGA logic: http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
The short forms using the shift operation I suspect will synthesize into the same multiplexer structure from the case statement. A variable shift operation (barrelshift) is a multiplexer of the same data under different shift distances. The shift amount maps to the select bits of the mux.
Like others have said try various codings and see if any give better results. It's easier to try various things and let synthesis do all the heavy lifting instead of the other way around :)
I don't assume significant differences in the synthesis results. The expression for each output signal should fit a 4-input -LUT, so it can be expected, that all logical equivalent descriptions end up in the same circuit.
--- Quote Start ---
--- Quote End ---
BadOmenthank you very much .
As you said,it will synthesize into the same multiplexer structure from the case statement
so if i interface a ROM
it can save so much resource ?
That is correct, you can use a small ROM as a lookup table based decoder. Just follow the ROM coding style in that link I posted. Keep in mind that this ROM will have a latency of one clock cycle.
A ROM is an option of course, but what do you mean with "save so much resource"?
