FPGA Intellectual Property
6669 Discussions
where can i find which ip's license needed?
Contributeur émérite II
1 474 Visites
after compiling a project, the information said:
Info: Design contains a time-limited core -- only a single, time-limited programming file can be generated
Warning: Can't convert time-limited SOF into POF, HEX File, TTF, or RBF
but i donn't know which ip need license. where can i find the detailed discription about which license?
thanks.
0 Compliments
1 Répondre
393 Visites
do you have any license ? quartus menue -> tools -> license setup
you need the subcription edition not the web edition
do you use the nios cpu ? if yes to need the subscription / license and that gives you a couple of license for most of the alter sopc ip's
do you use an ip from another company ?
unfortunately i have no idea if there is some kind of report telling you what license is missing.
from quartus 9.1 on the smalest nios -e is free and does not require a license.
0 Compliments
Répondre
