APEX fpga
Hi, I bought a Nios Excalibur board (second user). I thought I could use quartus II 10.0 web edition to run it but Apex FPGA is not an option when you open a new project. Is there any way I can play with this discontinued board or is it now just scrap:cry::cry:
Use 9.0 or 9.1. They support legacy FPGA.
Hi
Thanks for that. Will that be downloadable on the same machine as my 10.0 install??
Many thanks Graeme
Yes, you can install multiple version of Quartus II on the same machine.
Thanks for your help and happy new year.
Cheers Graeme.
I installed 9.1 but it doesn't support APEX either. I then installed 7.2 and it does. Tried a test project compiled it and went to program it only to find my USB blaster is no longer recognised by any version now. Windows recognises it when I plug in the usb cable and it is shown as working on the control panel. When I go to the programmer it only gives the option of eithernet connection.
Any Ideas :confused:
Cheers Graeme
Try update [roll back] USB-Blaster driver to 7.2.
Hi, Sorry don't quite understand what you mean. The first thing I tried was to uninstall the driver then booted down/up reinstalled driver all went well with no errors and the driver again being recognised by windows but still all versions of quartas doesn't recognise it. I seem to remrmber having this problem before. It was easy then because I only needed the most up to date version and could just reinstall and all was good but I now need both so can't start a fresh.:cry:
Thanks again for your help Graeme.
Sorry, I have come across with USB-Blaster problem on Windows7 only. Can you open an SR with Altera?
Re installed the stand alone programmer. It now works and so does 10.0 again. 7.2 still has the same problem but , if I load it then rerun the stand alone programmer and ask it to recognise usb blaster, close it then use the embedded 7.2 programmer it works after a few interogations?? I have sucessfully programmed the board using this method and once it works it continues to work until I shut down the program so no big deal.
Thanks again Graeme.
That's great. One thing to point out. The third-party USB-Blaster, for example, Terasic USB-Blaster has occasionally conflicts with other USB devices. I have encountered such scenarios, which I need to unplug everything, then replug the USB-Blaster only.
