6472 Discussions
Adding HPSGPIO/LOANIO to the signal tap analyzer
snehal_p
Nouveau contributeur I
1 035 Visites
Can we add hpsgpio/loanio to the signal tap analyzer.
I tried adding, but getting fitter error while compiling.
snehal_p
0 Compliments
6 Réponses
sstrell
Contributeur émérite III
1 019 Visites
If the signals show up with the Signal Tap filters in the Node Finder, then they can be tapped.  What error are you getting (full message)?
0 Compliments
snehal_p
1 002 Visites
PFA error message.
snehal_p
0 Compliments
sstrell
987 Visites
So they appeared in the Signal Tap Node Finder filter and yet after compilation, you still got these errors?  It looks like you're trying to tap the I/O themselves instead of the signals that feed (or are fed) by them.  Try tapping what they connect to on the FPGA side.
0 Compliments
JingyangTeh_Altera
974 Visites
Hi
It is a bit hard to give an advise just on the error code.
Would you mind sharing your project design for me to have a look?
Jingyang, Teh
0 Compliments
JingyangTeh_Altera
932 Visites
Hi
Any new information to update on this case?
Jingyang, Teh
0 Compliments
JingyangTeh_Altera
909 Visites
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
0 Compliments
Répondre
