6477 Discussions
Cyclone V Dev Kit - pin file
mjszekely
Is there some sort of pin file that Quartus can input to assign I/O pins for a given eval board instead of manually entering them?
I'm working on this Cyclone V dev kit
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-gt.html
sstrell
You can download and install a design template for your board, which should have the pinout set up for you.  You can then customize for your own design:
https://fpgacloud.intel.com/devstore/platform/?acds_version=any&board=24
AR_A_Intel
Hello
Yes, you can check and customize your design based on example in our Design Store.
AR_A_Intel
We have not heard from you and I hope all is well. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
