6472 Discussions
DE0-nano-SoC - Is it possible to reconfigure it at run-time?
Hi all,
as the title says, I would like to know that before buying.
Thanks!
So I've found this in the manual:
--- Quote Start ---
If developers wish to configure FPGA from an application software running on Linux, the MSEL[4:0]needs to be setto “01010”before the programming process begins. If developers using the "Linux Console with frame buffer" or "Linux LXDE Desktop" SD Card image, the MSEL[4:0]needs to be set to “00000” before the board is powered on.
--- Quote End ---
So basically the first option is what I want and the second one is the standard download the bitstream from PC?
Is therefore missing the possibility to configure the FPGA from Quartus?
