6478 Discussions
Debug server failing with "The script file ( device_browser.py ) failed during execution: See the error log for more information."
SDabh1
Hello All,
I have question regarding debug server on eclipse.
I am trying to run simple "Hello World" for ARM compiler bare-metal. For this I am following the guide "https://people.ece.cornell.edu/land/courses/ece5760/DE1_SOC/ug_soc_eds.pdf"
This pdf has a section for "Getting Started with ARM Compiler Bare-Metal Project Management"
Everything is going well but when I am trying to run debug configuration(debug_server) it fails with errror "The script file ( device_browser.py ) failed during execution: See the error log for more information." It is not able to find the JTAG connection (USB Blaster II). If I run the
"./jtagconfig" command I am able to find the JTAG.
I have attached screenshot.
I would be really grateful if anyone can help me with this error.
Thank you.
EBERLAZARE_I_Intel
Is this error pops up after you did the following?:
  • Select target to be Altera > Cyclone V SoC (Dual Core) > Bare Metal Debug > Debug Cortex-A9_0 and Target Connection to be USB-Blaster.
  • Click the Connection > Browse Button to select the connection to the target board.
Possible solution: Before running eclipse, you must set the system variables QUARTUS_ROOTDIR and LD_LIBRARY_PATH
Let me know if you need more help.
Regards.
Sasikumar_Agilex
Hi Team,
I am working on APOLLO AGILEX SOM BOARD using ARM Development Studio IDE Version: 2024.0, I am trying to develop a bare metal program during the debugger configuration I am facing this issue
In the environmental path I am missing the LD_LIBRARY_PATH how could I add it
