I am using the MAX V series CPLDs, I am experiencing different behavior of same RTL on the different models of MAX V CPLDs,
My RTL works fine on "5M570ZF256C5" but when I port the same onto "5M570ZT100A5N" the behavior gets changed completely.
I have attached the State Machine where I am facing the issue
CONFIGURE_ADC : process(clk) is
TYPE StateMachine IS(Init,D1,T1,B1,D2,T2,B2,D3,T3,B3,D4,T4,B4,Stop,Delay,Restart); --state machine data type
VARIABLE SPIState : StateMachine := Init; --State machine variable
variable fifo_memory : fifo_memory_type := (X"00",X"03");
variable read_memory : read_data_type := (X"00", X"00", X"00", X"00");
variable fifo_head : integer range 0 to 1 := 0;
variable read_head : integer range 0 to 3 := 0;
variable mux_flag : integer range 0 to 1 := 0;;
begin
if rising_edge(clk) then
--if(microseconds > 3000000) then
case SPIState is
when Init =>
if(mux_flag = 0) then
fifo_memory(0) := X"04";
--fifo_memory(1) := X"03";
mux_flag := 1;
SPIState := D1;
else
fifo_memory(0) := X"34";
mux_flag := 0;
SPIState := D1;
end if;
when D1 =>
fifo_head := 0;
cs_n <= '0';
if(busy_transfer = '0') then
read_head := 0;
read_memory(read_head) := spi_rx_data;
spi_tx_data <= fifo_memory(fifo_head);
SPIState := T1;
end if;
when T1 =>
trigger_transf <= '1';
SPIState := B1;
fifo_head := 1;
when B1 =>
if(busy_transfer = '1') then
trigger_transf <= '0';
SPIState := D2;
end if;
when D2 =>
read_head := 1;
SPIState := T2;
end if;
when T2 =>
SPIState := B2;
when B2 =>
SPIState := D3;
--cs_n <= '1';
end if;
when D3 =>
read_head := 2;
spi_tx_data <= x"00";
SPIState := T3;
end if;
when T3 =>
SPIState := B3;
when B3 =>
SPIState := D4;
end if;
when D4 =>
read_head := 3;
SPIState := T4;
end if;
when T4 =>
SPIState := B4;
when B4 =>
SPIState := Stop;
--cs_n <= '1';
end if;
when Stop =>
cs_n <= '1';
SPIState := Delay;
end if;
when Delay =>
counter <= counter + 1;
if(counter >= 3000000) then
SPIState := Restart;
counter <= X"00000000";
cs_n <= '0';
end if;
when Restart =>
if(miso = '0') then
SPIState := Init;
end if;
when others =>
null;
end case;
--end if;
end if;
end process CONFIGURE_ADC;
链接已复制
Thank you for your reply, basically this is a SPI Master State machine
In case when it works fine, it transmits 4 bytes of data continuously after a given delay
After porting it on the 5M570ZT100A5N the behavior becomes unpredictable, it sometimes transmits 2 bytes and stops for ever, sometimes it transmits 3 bytes and stops for ever, sometimes it transmits well for a duration of say 30 seconds and then stops.
I have no clue about the issue right know.
Thank you for your reply , Yes the clock speed is same in both devices, I am able to solve the problem by an alternate way i.e by replacing some SIGNALS with VARIABLES however i am still unclear that what is the problem in using SIGNALS,
I will share the sdc file shortly with you
Timing Analyzer Summary
Type : Setup 'CLK'
Slack : -26.114
TNS : -5667.650
Type : Hold 'CLK'
Slack : 1.728
TNS : 0.000
Type : Minimum Pulse Width 'CLK'
Slack : -2.289
TNS : -2.289
Type : Setup 'CLK'
Slack : -26.114
TNS : -5667.650
Type : Hold 'CLK'
Slack : 1.728
TNS : 0.000
Slack : -2.289
TNS : -2.289
sorry , got into other issue and couldnt able to reply timely ,
About the Signals and variables ,
There are lot of difference using signal and variables in RTL and one important difference is Variable assign the values immediately whereas signals depends on the logic use in the RTL (I.e mean combo or seq) . if Combo immdeiately assign it where as seq based on the logic it might take one /couple of clock cycles.
It is easy to understand if you create the test bench and see the RTL behavior in modelSIM.
About the timing , It looks really bad :(.Did you included the clock constraint ?
I am not sure what iam missing since both the CPLD from the same family and speed grade of the device are also same. here is what one more question Can you check the pin assignment since both are different package ? Also check the clock you connected to the global clock pins.
Thank you,
Sree
