6474 討論
Error while Custom Component Importing to Qsys
TBaki
初學者
4,321 檢視
I just added custom VHDL component in qsys. The module is just AND gate logic. I'm using quartus 13.1 version I'm getting error as,. Error: No modules found when analyzing null.
0 積分
21 回應
Nurina
員工
4,024 檢視
In this version of Quartus, if there was any error in your code, that error message would be all the Component Editor would display, which can be difficult for debugging. (this is a known bug that since been fixed in v17.1 https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2017/error--no-modules-found-when-analyzing-null.html)
Have you tried synthesizing the code directly in Quartus instead of through Qsys? It would provide detailed messages on any issues with the code. Once fixed, you can take it back through Qsys to build the component.
Another solution is to just migrate to a later version of Quartus where this issue is fixed.
Nurina
TBaki
初學者
4,021 檢視
The module got synthesized in quartus. I can't migrate to other version as I'm using Cyclone III FPGA. Higher version quartus won't support this FPGA
Nurina
員工
4,018 檢視
So after synthesizing on Quartus you tried to compile it on Qsys and only came across a problem there?
Do you get any error or warning messages on Quartus?
Nurina
sstrell
榮譽貢獻者 III
3,994 檢視
Can you post the code?
TBaki
初學者
3,985 檢視
Quartus II 64-Bit Version 13.1.0 Build 162.
Error is Error: No modules found when analyzing null.
sstrell
榮譽貢獻者 III
3,981 檢視
You have a semicolon at the end of
b : out std_logic
Remove the semicolon and you should be good to go.
Sidenote: technically this is a register, not an AND gate.
TBaki
初學者
3,960 檢視
Still not got fixed.
sstrell
榮譽貢獻者 III
3,941 檢視
It's blocked in your screenshot, but is the top-level module set correctly there on the Files tab in the Component Editor (as the error mentions)?
TBaki
初學者
3,933 檢視
What you mean by component editor in Quartus II 64-Bit Version 13.1.0 Build 162?
sstrell
榮譽貢獻者 III
3,920 檢視
The Component Editor is the tool you're using in the screenshot to create the custom component.
TBaki
初學者
3,903 檢視
Ok. Yes I selected top level. It didn't work.
Nurina
員工
3,949 檢視
Can you try analyze the HDL file again? I've tried to replicate your error and the problem is solved after removing the semicolon.
Nurina
TBaki
初學者
3,934 檢視
May I know which version of quartus tool you used. I used Quartus II 64-Bit Version 13.1.0 Build 162. Possible to share your .qpf file please
Nurina
員工
3,906 檢視
I used Quartus Prime Version 17.1. I believe that if it's analyzed correctly here it should be the same in v13.1 as well.
I've attached the .qar file here.
Nurina
TBaki
初學者
3,905 檢視
Version 15, 16 17 ..it will work. Try with version I mentioned. With version 16 it worked for me. 13.1 didn't work. so posted the query. Thanks
Nurina
員工
3,898 檢視
Can you try remove 'is' after 'process(clk)' and see if there's a difference there?
Nurina
TBaki
初學者
3,897 檢視
Removed 'is'. But, no luck
Nurina
員工
3,893 檢視
Can you try put parentheses after your first if statement like so
if (rising_edge(clk)) then
additionally try with and without the 'is' from my previous reply.
Nurina
TBaki
初學者
3,903 檢視
I tried but didn't work
Nurina
員工
3,891 檢視
I tried on Quartus II 64-Bit Version 13.1.0 Build 162 and it seems to work fine. Could you take a look?
Nurina
回覆
