6472 Discussions
I facing error while simple VHDL code is simulation is done.
BDE
POSIX EACCES(Permission denied)
check the nativelink log files [....]
error message OR
Pl see the attachement.
HBhat2
New Contributor II
Please provide more info on your OS, Modelsim Version (Downloaded from Intel website or Standalone version) etc.
Normally Permission denied cases come where the particular folder doesn't have write permission (If the pwd (present working Directory) is in C drive).
Try to change the working Directory to other directory using cd command after launching Modelsim.
With Regards,
HPB
BDE
sorry for delay in reply,
OS: Windows 7 enterprise SP1
Modelsim Version: ModelSim - Intel FPGA Edition 10.5b
Modelsim is not opening from Prime software but it is working alone when it opens.
all the Permission are provided to access.
thanks for your support.
regards,
Balakrishna
RichardTanSY_Altera
I think you might need to setup the nativelink and simulation setting. You can refer to the link below:
https://www.intel.com/content/www/us/en/programmable/documentation/sam1412662001635.html#sam1412661740468
If invoke modelsim from Intel Quartus Prime Software, do you still see the same error?
