6457 Discussions
Inquiry about Power On/Off Pin for Intel FPGA Arria 10 Dev Board (10AX115S-A)
Tora
I am using the Intel FPGA Arria 10 Development Board (10AX115S-A). I would like to know if there are any additional pins available on the board that provide the power on/off function, apart from the power switch located on the front of the board.
Thank you.
sstrell
It's a dev kit so I wouldn't think so.  What is your intention?  Board schematic: https://cdrdv2.intel.com/v1/dl/getContent/649801
Tora
Our intention is to reset the FPGA by cutting off the power and reloading the program when an abnormal situation occurs. We are looking for a way to control the power on/off through pins, if possible.
Thank you for your help.
sstrell
You can force reconfiguration at any time, but obviously this would be hardware configured on your own board, not a dev kit: https://www.intel.com/content/www/us/en/docs/programmable/683461/current/configuration-error-handling.html
If you're saying that you need to power cycle the whole device and not just reconfigure it on the dev kit, then I think you'd have to modify the board.
NazrulNaim_Intel
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
NazrulNaim_Intel
Regarding your request. Please access through the link below.
Link : https://cdrdv2.intel.com/v1/dl/getContent/666433?fileName=an738-683555-666433.pdf
Hope that helps.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
