公告
Setting output delay
SKon1
新手
2,112 次查看
I want to constrain my system (attached) for input and output delays.
The input delay is straightforward. But I have my doubts about the output delay.
This is what I did for the input delay:
create_clock -name clock_in -period 10.000 [get_ports {clock_in}]
set_input_delay -clock clock_in -max 1.0 [get_ports data_in]
set_input_delay -clock clock_in -min 0.1 [get_ports data_in]
Now, what should I do to specify the output delay ?
What clock should be used for reference ?
clock_in ?
set_output_delay -clock clock_in -max -1.0 [get_ports data_out]
set_output_delay -clock clock_in -min -0.1 [get_ports data_out]
Or clock_out ?
set_output_delay -clock clock_out -max -1.0 [get_ports data_out]
set_output_delay -clock clock_out -min -0.1 [get_ports data_out]
0 项奖励
12 回复数
sstrell
名誉分销商 III
2,020 次查看
You have created a single data rate source synchronous interface, so you have to create a generated output clock as the reference clock. See this online training for the details:
Constraining Source Synchronous Interfaces
#iwork4intel
SKon1
新手
2,020 次查看
So I should first use the "create_generated_clock" command like this:
create_generated_clock -name clock_out -source [get_ports {clock_in}] [get_ports {clock_out}]
And then use the the generated clock as reference:
set_output_delay -clock clock_out -max -1.0 [get_ports data_out] set_output_delay -clock clock_out -min -0.1 [get_ports data_out]
Correct ?
0 项奖励
sstrell
名誉分销商 III
2,020 次查看
Yes, that looks good. Your max and min values should of course be based on the timing requirements of the "downstream" device that you are connecting to, and usually those values (or at least not both of them) aren't negative. Do you have setup/hold info or skew info for the downstream device?
#iwork4intel
SKon1
新手
2,020 次查看
That was a theoretical question - so the actual setup/hold times aren't relevant.
Is there another lecture on DDR interfaces ?
0 项奖励
sstrell
名誉分销商 III
2,020 次查看
SKon1
新手
2,020 次查看
If any Intel employee sees this - both lectures don't work well when they're downloaded as a zip file.
It launches, you can hear the speech - but the slides don't show on the screen.
On the web it works fine.
0 项奖励
KennyTan_Altera
主持人
2,020 次查看
Hi Shai Kon,
We was able to see this as well. we will get our Intel IT to fix this .
0 项奖励
sstrell
名誉分销商 III
2,020 次查看
In the .zip file, run Launch_Presentation.exe. This will run the training. The instructions supplied when you registered should have mentioned this.
#iwork4intel
0 项奖励
KennyTan_Altera
主持人
2,020 次查看
Steve was right, I will had our IT to have a readme.txt files for enhancment.
0 项奖励
SKon1
新手
2,020 次查看
There is NO file named Launch_Presentation.exe in the zipped archive
0 项奖励
sstrell
名誉分销商 III
2,020 次查看
I just realized these are older trainings that don't include the Launch_Presentation.exe executable. As such, use the presentation_html5.html file (instead of presentation.html) to run these trainings in a modern browser (without Flash).
#iwork4intel
0 项奖励
KennyTan_Altera
主持人
2,020 次查看
Sorry, what I mean is click on
launcher.html
It work from my side.
0 项奖励
回复
