below listed the setup and issue
- Server setup with ubuntu 18.04
- Installed quartus prime pro 21.2 on the server (added USB driver as specified on web)
- Plugged stratix-10 MX card on PCI slot, added power cable (J11) and connected USB cable (for bitfile download)
- ISSUE: Not able to find the hardware (FPGA) on the programmer window of quartus
any suggestions, what am i doing wrong here?
May I know if you are able to check SW2 switch (https://www.intel.com/content/www/us/en/programmable/documentation/cbc1517362051825.html Figure 3) to see if include the S10? If yes, what do you observed when you performed auto detect in Quartus Programmer?
HI, SW2 switch is in off, off, on, off (1,2,3,4) position. SW2_S10 is in off state.
Autodetect is not helping in detecting the board, programmer window just waits and come back to previous state (no message)
Could you try changing your SW2 to OFF, ON, ON, OFF and OFF, OFF, ON, ON? Then provide me the Quartus Programmer message for both the SW2 switch setting.
Device is visible after setting SW2 to OFF, ON, ON, OFF position. thanks.
Glad to hear that the issue is resolved after changing the SW2 switch.
