6471 Discussions
Structure of Cyclone Ⅴ and EPCQ-A
NAika
I am trying to realize the Cyclone V configuration using EPCQ-A(AS Mode).
EPCQ-A
 Output Delay(tCLQX) min 1.5ns
Cyclone V
 Input hold time(tDH) min 2.9ns
Could you tell me what kind of connection method is there?
(CR etc...)
Nooraini_Y_Intel
Hi NAika,
You can follow the guideline under chapter “1.4 Evaluating Data Setup and Hold Timing Slack” in AN822 to evaluate the data hold time slack on your board in order to ensure you are meeting the Cyclone V data hold time (tDH) requirement.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an822.pdf
Also, you can refer to the following KDB for other recommendation that you can consider for Cyclone V AS configuration board design:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2018/why-does-cyclone-v-as-configuration-with-epcq-epcqa-devices-fail.html
Nooraini
NAika
The DCLK pin can not be connected directly with Spec specified below.
EPCQ-A
Cyclone V
(CR etc...)
a_x_h_75
New Contributor III
Good spot. I think the datasheet for the EPCQ device is misleading. I think the problem is that Intel/Altera always capture the figures from the FPGA's point of view - if that makes sense (I'm not sure it does...)
Refer to figure 53 (page 95) of the equivalent Micron part. All timings, and in particular t_CLQV & t_CLQX are with respect to the rising edge of the clock:
https://www.micron.com/~/media/documents/products/data-sheet/nor-flash/serial-nor/mt25q/die-rev-b/mt25q_qlkt_l_512_abb_0.pdf
Given data is latched into the FPGA on the falling edge of DCLK I think perhaps Intel/Altera have tried to reference the same edge in the memory device's datasheet when, I suspect, they're no different to the Micron (or other 3rd party) devices.
Cheers,
Alex
Nooraini_Y_Intel
Hi NAika,
Nooraini
NAika
Thank you for answer.
We will consider it.
