6471 Discussions
Technology Map Viewer Post-Fitting signal names
BMart12
I am using the SignalTap II logic analyzer on Quartus Prime Version : 18.1.1 Build 646 04/11/2019 SJ Standard Edition.  I am tracing logic in the Cyclone V SOC to debug a memory-mapped slave interface using the post-fit map viewer.  I want to know what the tilde (~) signifies in a signal name.  As an example, I have a problem with the decoding of the addresses instantiated in the slave interface.  I want to trigger on either slave_reg_read or slave_reg_write.  The map shows two signals that I interpret are for slave_reg_read: m0_read and m0_read~0.  The LA trace shows that m0_read is active low and m0_read~0.  The two signals are in sync.  So does the tilde indicate not m0_read?
For slave_reg_write the map shows two signals: m0_write~[0..1].  The LA trace shows that m0_write~1 is active low and m0_write~0 is active high, with both signals in sync.  Does the tilde before the [0..1] indicate something?
Thank you in advance.
sstrell
Names can get distorted through the place and route process.  The ~ does not necessarily mean anything other than the name of a signal changed or a new internal signal was created through this process.  If you know the signals you want to tap from your design itself, use the Signal Tap pre-synthesis Node Finder filter instead of post-fit nodes you find in the Tech Map Viewer.
sstrell
YEan
Hi there,
Do you have any update on your problem?
Thank you.
Ean
YEan
I’m think that your issue has been resolved by sstrell.
I'll now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
Ean
BMart12
I apologize for the delay in my response.  I missed sstrell's response.  I accepted his suggestion.
