6478 Discussions
programmer error with Intel S10mx development kit
clair
    I tried to program .sof file into Intel S10mx development kit,but failed.
I reboot the PC several times and I try different PC, the errors came up the same .
Error(18952): Error status: Synchronization failed
Error(20068): Configuration error, you must power-cycle the device to recover from this condition. To avoid this error you must ensure that the device is configured within 18 seconds after completion of the power-on sequence.
Error(209012): Operation failed
JohnT_Intel
clair
Hi, John
   I did program the fpga after power up.
   The link you mentioned above provide the solution for S10 SX/GX, not for S10mx. And I have tried the  Patch 0.13 Link, and it didn't work.
Best regards
JohnT_Intel
If you look into the KDB, it mention it is happening on ES1 device of Stratix 10 MX device. May I know if you are still seeing the same issue if you immediately program the FPGA after power up?
Impacted Stratix 10 MX variants
  • Intel Stratix 10 MX 2100 H-Tile ES1
clair
Hi,JohnT
     I said I have tried the solution, but it did not work.
     Now I can solve the problem by power off the mainboard and restart. However I've been trying to type “reboot” to restart the computer which often failed.
JohnT_Intel
May I know when you performed reboot, is the board configured? The reason is that reboot will not power cycle the FPGA>
