I have a brand new Arria 10 FPGA dev kit. I have set all the switches appropriately, according to the User Guide. When using the Quartus Programmer I get the following error after autodetecting the device:
"Can't recognise the Flash device that attached to device 2. The Flash device is not supported by Quartus Prime software" Error 18591
I am able to use the Board Test System software provided (program the device with the GPIO/Flash sof file, for example).
Karl
链接已复制
Hi Sree,
I seem to have let your reply slip past me - apologies.
I am still getting the same error message with a JTAG frequency of 6M or 24M.
I am able to program the Arria 10 directly with a SOF file but as the software can't identify the Flash I'm unable to program it with a POF.
Karl
Can you check the Board bypass setting ? I remember i saw in hw board having options to by pass the flash etc , iam not sure here what will be the problem ..I do have Arria 10 SOC kit and GX kit ..both working fine and i am able to access the same .
Hope we are missing some setting .
Thank you ,
Sree
