High-Speed Transceiver Demo Designs - IV-series (StratixIV GX)
cancel
Showing results for
Search instead for
Did you mean:
340 Discussions
High Speed Transceiver Demo Designs - IV - Series (StratixIV GX)
Stratix IV GX
Recovered Clock Generation and System Clock Generation using GPLL (no cascading)
  • Stratix IV GX SI board: 1 Channel 64b66 encoded design at 6.25Gbps with creation of recovered clock and system clock through GPLL
         GXIV_SIBoard_1Ch_64b66b_Clock_Recovery_GPLL.zip
Recovered Clock Generation for Oversampling Based Designs
  • Stratix IV GX SI board: 1 Channel Multi-PRBS design at OC-3 rate using oversampling and creation of recovered clock through GPLL
         GXIV_SIBoard_1Ch_Multi_Prbs_155Mbps_Clock_Recovery.zip
AEQ and EyeQ
  • Stratix IV GX SI board: 6 Channels Multi-PRBS design (using socket oscillator) with AEQ and EyeQ enabled
         GXIV_SIBoard_6Ch_Multi_Prbs_Socket_Oscillator_EyeQ_ADCE.zip
EyeQ
  • Stratix IV GX SI board : 6 Channels Multi Prbs design (using socket oscillator) with EyeQ
         GXIV_SIBoard_6Ch_Multi_Prbs_Socket_Oscillator_EyeQ.zip
SoftCDR & LVDS_PHY
  • Stratix IV GX PCIe Board: 4Ch LVDS_PHY_SoftCDR Demo at 1.25Gbps per Channel
         SIVGX_DevKit_LVDS_Phy_1250Mbps_SoftCDR_4Ch_SFP.zip
Aurora
  • Stratix IV GX SI board: Aurora demo Design : 1 lane at 2.5Gbps
         GXIV_SI_Board_Aurora_1_Lane_2500Mbps.zip
SFI5.1
  • Stratix IV GX SI board: 17 Channel Multi Prbs at 3.125Gbps using SFI5.1
         GXIV_SIBoard_17Ch_Multi_Prbs_3125Mbps_16bit_SFI51_Implementation.zip
XAUI
  • Stratix IV GX SI board: XAUI Demo Design
         GXIV_SIBoard_XAUI_Demo.zip
Dynamic Reconfiguration
  • Stratix IV GX SI board: Dynamic Reconfigurable Demo Design from XAUI <=> DXAUI
         GXIV_SIBoard_DXAUI_XAUI_Demo.zip
  • Stratix IV GX SI board: Dynamic Reconfigurable Demo Design from XAUI <=> GbE <=> GIG3
         GXIV_SIBoard_XAUI_GbE_GIG3.zip
  • Stratix IV GX SI board: 1Ch Dynamic Reconfiguration (Multi Rate Sonet, GbE, GIG3, FC-4 w/ 4 Input Clocks)
         GXIV_SIBoard_1Ch_Multirate_Sonet_GbE_FC4_4_input_clocks.zip
  • Stratix IV GX SI board: 2Ch Dynamic Reconfiguration (Multi Rate Sonet, GbE, GIG3, FC-4 w/ 4 Input Clocks)
         GXIV_SIBoard_2Ch_Multirate_Sonet_GbE_FC4_4_input_clocks.zip
Synchronous
  • Stratix IV GX SI board: 20Gbps Synchronous Demo 4 Scrambled Lanes at 5Gbps w/ Simple Training and Deskew
         GXIV_SIBoard_Synchronous_4_Channels_5Gbps.zip
Seriallite II
  • Stratix IV GX Devkit: Seriallite II Demo Design Using LVDS: 4 lanes at 1.25Gbps
         GXIV_DevKit_SerialliteII_LVDS_4Ch_1250Mbps.zip
  • Stratix IV GX SI Board: Seriallite II Demo Design: - 4 lanes at 6.25Gbps using PMA Only Channels
         GXIV_SIBoard_Seriallite_4_Lanes_6250Mbps_PMA_Only.zip
  • Stratix IV GX SI Board: Seriallite II Demo Design: - 4 lanes at 6.25Gbps (Onboard 312.5Mhz XO)
         GXIV_SI_Board_Seriallite_4_Lanes_6250Mbps.zip
  • Stratix IV GX SI Board: Seriallite II Demo Design: - 4 lanes at 8.5Gbps with external 8b10b PCS (Onboard 425Mhz XO)
         GXIV_SI_Board_Seriallite_4_Lanes_8500Mbps.zip
  • Stratix IV GX SI board: Seriallite II Demo Design - 4 lanes at 8.5Gbps with internal 8b10b (Onboard 425 Mhz XO)
         GXIV_SIBoard_Seriallite_4_Lanes_8500Mpbs.qar
         (Note: The link above is only the Quartus II archive, for documentation please see the above 6.25Gbps design.)
SuperLite V2
  • Stratix IV GX SI board: Superlite V2 demo Design: 2 lanes at 4Gbps with Avalon ST Transmit Interface
         GXIV_SIBoard_Superlite_v2_2_Lanes_4000Mbps_Avalon_ST.zip
SuperLite
  • Stratix IV GX SI Board: SuperLite Demo Design: 6 lanes at 6.25Gbps using embedded PCS in ALTGX
         GXIV_SIBoard_Superlite_6_Lanes_6250Mbps_PCS.zip
  • Stratix IV GX SI Board: SuperLite Demo Design: 2 lanes at 4Gbps using embedded PCS in ALTGX
         GXIV_SIBoard_Superlite_2_Lanes_4000Mbps.zip
  • Stratix IV GX SI Board: SuperLite Demo Design: 2 lanes at 6.25Gbps using PMA only channels or mixed mode
         GXIV_SIBoard_Superlite_2_Lanes_6250Mbps_PMA_and_MIX.zip
  • Stratix IV GX SI Board: SuperLite Demo Design: 4 lanes at 8.5Gbps (Onboard 450Mhz XO)
         GXIV_SIBoard_Superlite_4_Lanes_8500Mbps.zip
Version history
Last update:
‎07-16-2020 08:35 AM
Updated by:
