So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[This is the dawning of the age of Colossus, where peace is compulsory, freedom is forbidden, and man’s greatest achievement is man’s greatest mistake.]
Hello Trillape,
Aside from the SSU logs, let me also ask the following details:
- Was it working fine before?
- What was the last change made in the system before the issue started?
- What is your game launcher?
Thanks for assistance.
Michael L.
I lastly changed the driver by updating it.
I’m using steam to launch it, although I downloaded it outside of steam
Hello Trillape,
Thank you for the update.
I was wondering if you can also send the SSU logs that the other forum user asked for me to further check your system.
However, let me also inform you that your game requirement is higher that Graphics card. You may check the link below:
Marvel’s Spider-Man Remastered system requirements | Can I Run Marvel’s Spider-Man Remastered
Michael L.
It's attached below. other people got the same system as mine, and been playing it smoothly.
Message Body
Hello Trillape,
I checked your SSU logs and found that you are already using the latest Graphics driver.
Going back to my previous post, the game requirement is higher than your embedded Graphics.
Have you tried to check with the game developer regarding this issue?
Michael L.
Hello Trillape,
Michael L.
Hello Trillape,
I am sending another follow up on the information that I requested.
Michael L.
