http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23713 Windows 32-bit
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714 Windows 64-bit
Discussion on this driver should be directed on this thread: /thread/49681 https://communities.intel.com/thread/49681
Thanks all who participated in the beta driver program. Your feedback was very much appreciated.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23644 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23644
All,, uninstalling the current driver will not make your system unusable. I would recommend creating a Restore Point first to have a known good configuration to restore to in the event the results are not what you expected.
I can confirm that installing the new driver using the instructions previously provided fixes all problems and allows for regular gameplay of Titanfall. Damn fine work, gentlemen. That was fast.
I was encountering the black screen on driver installation.
Toshiba Satellite C855
Windows 8.1 64-bit
Intel Core i3-3120M 2.50GHz
6.00 GB Ram
I installed the newest driver. The process went smoothly. I immediatly jumped into Titanfall. I played for two hours flawlessly. Well done.
A lot of people say integrated cards won't work on games but I have been using this card for 13 months and playing all of the games I want to play. You have produced a quality product and surprised me with the driver update.
Would my computer perform better if I uninstalled the old driver and installed this new one? I downloaded the new driver without uninstalling the old driver.
Confirming that Thief suffers from displaying some textures in the lowest resolution. HD 4000.
i did. i never installed the first driver since a lot of people were getting black screens and had to use external monitors to play the game. so posting the instructions would be a really big help. sorry im kind of a noob when it comes to stuff like this.
I can now confirm tTheSpeakman's assertion that the driver works. The models and map elements are intact so far, and I can see the gun in the player character model's hand. Fine work, gentlemen.
Here to report that install went smoothly, graphics are fixed, no black screen anymore. Fantastic job guys!
I'm getting an error message saying the driver isn't validated for my laptop so I guess this means this driver is incompatible with Intel HD 4000. Time to work on getting my refund now.
@AAllen follow these steps and make sure that you uninstall previous drivers
f you need to Uninstall:
To uninstall the existing graphics driver:
1. Open the Control Panel
2. Click "Programs and Features"
3. Select the "Intel Graphics Driver" from the list
4. Click Uninstall
5. When the uninstall is complete, reboot the system and then install the updated beta graphics
1. Login with administrator privileges
2. Open Control Panel
3. Open Device Manager
4. Click on "Display adapters"
5. Double click "Intel HD Graphics"
6. Click on the "Driver" tab
7. Click on "Update Driver" button
8. Click on "Browse my computer for driver software"
9. Click on "Let me pick from a list of device drivers on my computer"
10. Click on "Have Disk" button
11. Click "Browse"
12. Navigate to the folder that you unzipped the Beta Intel HD Graphics driver to
13.Navigate to the Graphics sub-folder
14. Double click the igdlh64.inf or igdlh.inf file <-- depends on if you have 32 or 64 bit OS
15.Click "OK"
16. Click "Next"
Driver should now be installing.
17. If successful, click "Close"
Reboot.
All Credit Goes to Robert_U @ Intel and tupper93 : I used their instructions to successfully update with HD 4000 (See my previous post for processor)
WOrks but screen tearing is still heinous and the game is very unplayable. Idk if anyone else is having the same problem but aiming is very hard online with this amount of screentear
Worked for me! Thanks a lot for the quick work.
Lenovo ThinkPad Twist with Intel HD4000.
Still no word on the HD 3000?
but yeah fps has improved by 3 fps hope you guys also fix this texture glitch
I also still have these texture glitches and blurry textures on my HD4000 when playing Thief.
Thanks for the feedback on Thief. We are looking into it.
Robert
btw here is the log file
11:19:56:766 (2588) > THIEF (64-bit)
11:19:56:798 (2588) > ==============
11:19:56:843 (2588) >
11:19:56:859 (2588) >
11:19:56:890 (2588) > Memory statistics:
11:19:56:921 (2588) > Total RAM = 3.9 GB (3973 MB)
11:19:56:955 (2588) > Avail RAM = 2.8 GB (2863 MB)
11:19:56:966 (2588) > Total virtual memory = 131072.0 GB (134217727 MB)
11:19:56:997 (2588) > Avail virtual memory = 131071.9 GB (134217580 MB)
11:19:57:029 (2588) > OS = Windows 8 (build 9200)
11:19:57:060 (2588) > [Main] Version: 1.2 build 4116.4
11:19:57:090 (2588) > [Main] Command line: -nolauncher
11:19:57:114 (2588) > [Main] Base directory: D:\Steamapps\common\Thief\Binaries2\Win64\
11:19:57:213 (2588) > [Platform] CPU Page size=4096, Processors=4
11:19:57:245 (2588) > [Platform] High frequency timer resolution =2.533316 MHz
11:19:57:276 (2588) > [CPUCount] -----------------------------------------
11:19:57:301 (2588) > [CPUCount] GetLogicalProcessorInformation results:
11:19:57:343 (2588) > [CPUCount] -----------------------------------------
11:19:57:367 (2588) > [CPUCount] Number of NUMA nodes: 1
11:19:57:398 (2588) > [CPUCount] Number of physical processor packages: 1
11:19:57:422 (2588) > [CPUCount] Number of processor cores: 2
11:19:57:454 (2588) > [CPUCount] Number of logical processors: 4
11:19:57:478 (2588) > [CPUCount] Number of processor L1/L2/L3 caches: 4/2/1
11:19:57:614 (2588) > [Render] NxApp PreInit
11:19:57:645 (2588) > [Render] Enumerating adapters:
11:19:57:676 (2588) > [Render] Adapter 0:
11:19:57:700 (2588) > Description : Intel(R) HD Graphics 4000
11:19:57:731 (2588) > Vendor : Intel (8086)
11:19:57:755 (2588) > Device : 166
11:19:57:787 (2588) > Sub system : 17f3103c
11:19:57:811 (2588) > Revision : 9
11:19:57:842 (2588) > Dedicated Video Memory : 0032 MB
11:19:57:866 (2588) > Dedicated System Memory : 0000 MB
11:19:57:897 (2588) > Shared System Memory : 1760 MB
11:19:57:922 (2588) >
11:19:57:953 (2588) > [Render] Adapter 1:
11:19:57:977 (2588) > Description : Microsoft Basic Render Driver
11:19:58:008 (2588) > Vendor : Unknown (1414)
11:19:58:033 (2588) > Device : 8c
11:19:58:064 (2588) > Sub system : 0
11:19:58:088 (2588) > Revision : 0
11:19:58:120 (2588) > Dedicated Video Memory : 0000 MB
11:19:58:144 (2588) > Dedicated System Memory : 0000 MB
11:19:58:175 (2588) > Shared System Memory : 0256 MB
11:19:58:200 (2588) >
11:19:58:230 (2588) > [Render] Enumerating monitors:
11:19:58:255 (2588) > [Render] Monitor 0: handle = 0000000000010001, aspect = 1.78
11:19:58:286 (2588) >
11:19:58:315 (2588) > [Render] Enumerating Display Modes:
11:19:58:347 (2588) > [Render] Monitor 'Display 1 (Intel(R) HD Graphics 4000(1))' (0000000000010001):
11:19:58:375 (2588) > [Render] - Mode 0 : 320 x 200 @ 40 Hz, stereo = 0
11:19:58:399 (2588) > [Render] - Mode 1 : 320 x 200 @ 40 Hz, stereo = 0
11:19:58:430 (2588) > [Render] - Mode 2 : 320 x 200 @ 60 Hz, stereo = 0
11:19:58:472 (2588) > [Render] - Mode 3 : 320 x 200 @ 60 Hz, stereo = 0
11:19:58:533 (2588) > [Render] - Mode 4 : 320 x 240 @ 40 Hz, stereo = 0
11:19:58:551 (2588) > [Render] - Mode 5 : 320 x 240 @ 40 Hz, stereo = 0
11:19:58:577 (2588) > [Render] - Mode 6 : 320 x 240 @ 60 Hz, stereo = 0
11:19:58:608 (2588) > [Render] - Mode 7 : 320 x 240 @ 60 Hz, stereo = 0
11:19:58:633 (2588) > [Render] - Mode 8 : 400 x 300 @ 40 Hz, stereo = 0
11:19:58:663 (2588) > [Render] - Mode 9 : 400 x 300 @ 40 Hz, stereo = 0
11:19:58:688 (2588) > [Render] - Mode 10 : 400 x 300 @ 60 Hz, stereo = 0
11:19:58:765 (2588) > [Render] - Mode 11 : 400 x 300 @ 60 Hz, stereo = 0
11:19:58:832 (2588) > [Render] - Mode 12 : 512 x 384 @ 40 Hz, stereo = 0
11:19:58:885 (2588) > [Render] - Mode 13 : 512 x 384 @ 40 Hz, stereo = 0
11:19:58:932 (2588) > [Render] - Mode 14 : 512 x 384 @ 60 Hz, stereo = 0
11:19:58:965 (2588) > [Render] - Mode 15 : 512 x 384 @ 60 Hz, stereo = 0
11:19:59:007 (2588) > [Render] - Mode 16 : 640 x 400 @ 40 Hz, stereo = 0
11:19:59:032 (2588) > [Render] - Mode 17 : 640 x 400 @ 40 Hz, stereo = 0
11:19:59:060 (2588) > [Render] - Mode 18 : 640 x 400 @ 60 Hz, stereo = 0
11:19:59:087 (2588) > [Render] - Mode 19 : 640 x 400 @ 60 Hz, stereo = 0
11:19:59:116 (2588) > [Render] - Mode 20 : 640 x 480 @ 40 Hz, stereo = 0
11:19:59:142 (2588) > [Render] - Mode 21 : 640 x 480 @ 40 Hz, stereo = 0
11:19:59:171 (2588) > [Render] - Mode 22 : 640 x 480 @ 60 Hz, stereo = 0
11:19:59:198 (2588) > [Render] - Mode 23 : 640 x 480 @ 60 Hz, stereo = 0
11:19:59:227 (2588) > [Render] - Mode 24 : 800 x 450 @ 40 Hz, stereo = 0
11:19:59:253 (2588) > [Render] - Mode 25 : 800 x 450 @ 40 Hz, stereo = 0
11:19:59:282 (2588) > [Render] - Mode 26 : 800 x 450 @ 60 Hz, stereo = 0
11:19:59:309 (2588) > [Render] - Mode 27 : 800 x 450 @ 60 Hz, stereo = 0
11:19:59:337 (2588) > [Render] - Mode 28 : 800 x 600 @ 40 Hz, stereo = 0
11:19:59:364 (2588) > [Render] - Mode 29 : 800 x 600 @ 40 Hz, stereo = 0
11:19:59:393 (2588) > [Render] - Mode 30 : 800 x 600 @ 60 Hz, stereo = 0
11:19:59:442 (2588) > [Render] - Mode 31 : 800 x 600 @ 60 Hz, stereo = 0
11:19:59:498 (2588) > [Render] - Mode 32 : 960 x 540 @ 40 Hz, stereo = 0
11:19:59:552 (2588) > [Render] - Mode 33 : 960 x 540 @ 40 Hz, stereo = 0
11:19:59:598 (2588) > [Render] - Mode 34 : 960 x 540 @ 60 Hz, stereo = 0
11:19:59:626 (2588) > [Render] - Mode 35 : 960 x 540 @ 60 Hz, stereo = 0
11:19:59:653 (2588) > [Render] - Mode 36 : 960 x 720 @ 40 Hz, stereo = 0
11:19:59:681 (2588) > [Render] - Mode 37 : 960 x 720 @ 40 Hz, stereo = 0
11:19:59:709 (2588) > [Render] - Mode 38 : 960 x 720 @ 60 Hz, stereo = 0
11:19:59:737 (2588) > [Render] - Mode 39 : 960 x 720 @ 60 Hz, stereo = 0
11:19:59:765 (2588) > [Render] - Mode 40 : 1024 x 576 @ 40 Hz, stereo = 0
11:19:59:792 (2588) > [Render] - Mode 41 : 1024 x 576 @ 40 Hz, stereo = 0
11:19:59:820 (2588) > [Render] - Mode 42 : 1024 x 576 @ 60 Hz, stereo = 0
11:19:59:848 (2588) > [Render] - Mode 43 : 1024 x 576 @ 60 Hz, stereo = 0
11:19:59:876 (2588) > [Render] - Mode 44 : 1024 x 768 @ 40 Hz, stereo = 0
11:19:59:903 (2588) > [Render] - Mode 45 : 1024 x 768 @ 40 Hz, stereo = 0
11:19:59:931 (2588) > [Render] - Mode 46 : 1024 x 768 @ 60 Hz, stereo = 0
11:19:59:959 (2588) > [Render] - Mode 47 : 1024 x 768 @ 60 Hz, stereo = 0
11:19:59:987 (2588) > [Render] - Mode 48 : 1152 x 640 @ 40 Hz, stereo = 0
11:20:00:014 (2588) > [Render] - Mode 49 : 1152 x 640 @ 40 Hz, stereo = 0
11:20:00:042 (2588) > [Render] - Mode 50 : 1152 x 640 @ 60 Hz, stereo = 0
11:20:00:069 (2588) > [Render] - Mode 51 : 1152 x 640 @ 60 Hz, stereo = 0
11:20:00:118 (2588) >...
well speaking of texture glitches due to memory leaks, even trials evolution has such glitches but in much magnified intensity; it would be great to see these type of issues fixed
From time to time when playing Thief, the driver crashes and Thief stops responding. When in full screen mode i have to press alt+ctrl+del and logoff. In windowed mode, i can kill the process through windows taskmanager or through cmd > taskkill. I must note the driver is much more stable with Thief. The latest stable version crashed thief any random time. While with the latest beta driver i could play for 2 hours.
notice: Win8.0 x64, Intel HD4000, intel x64 driver, Thief x64 version
Then there is the problem while looking around, that sometimes surfaces turn black or sometimes dark.
I also noticed that when a surface turns black and there is a "blood spatter" texture over it, the blood spatters gets very blurry and pixelated.
Garret's hands are black when entering Basso's hideout.
- Last part are just blurry textures. Paintings, books in shelves, news papers, road signs. Even in chapter 4 A friend in need when Garret holds the large map in the cut scene, the whole map is unreadable.
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
