- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Add me to the list of people who get a black screen....
HP G60t-200CTO
Windows 7 64 bit.
I uninstalled the previous intel driver (8.15.10.1986) and installed 8.15.10.2086.. and got a black screan... grrr... Other older intel drivers have worked just fine so I don't agree that it's a special vendor bios issue.
-Devoh
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thanks everyone for providing your system information.
So far it appears the issue only occurs on mobile/laptop systems. That is why I do not see it when testing on desktop systems.
Typically, laptop manufacturers add customizations to the graphics driver and/or VBIOS that is specific to their systems and how they want them to perform. For laptops, I always recommend that you run the latest supported and tested driver for your system provided by the systems manufacturer. If there is and issue with the driver provided by your system manufacturer, it is best to contact them to find a resolution for the issue and only use the generic driver from Intel as a last resort knowing that it may not perform correctly due to system customizations.
We are continuing to test this issue on the mobile systems we have at our disposal but so far have not been able to replicate it. This leads me to believe it is a customization issue. We will continue to look at this however, I recommend that if you are seeing this issue, that you use the latest supported driver on your systems manufacturers web site.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Mine isn't a laptop. It's a home built desktop.
OS: Windows XP Pro SP3
Mother board: ASUS P7H57D-V EVO
CPU: i5 660
I was hoping enough info was gathered from everyone else. If you really need my setup information as well I can remove the video card and install latest intel driver that causes the issue.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Yes,, please post you system info. Also post the display make and model and the resolution you are running.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I'm using a Sony Vaio VGN-FW270J with the built-in screen running at a resolution of 1600x900.
Intel® Graphics Media Accelerator Driver for Mobile Report
Report Date: 4/20/2010
Report Time[hr:mm:ss]: 18:26:54
Driver Version: 8.15.10.2021
Operating System: Windows 7 (6.1.7600)
Default Language: English (United States)
DirectX* Version: 10.0
Physical Memory: 3935 MB
Minimum Graphics Memory: 128 MB
Maximum Graphics Memory: 1759 MB
Graphics Memory in Use: 22 MB
Processor: Intel64 Family 6 Model 23 Stepping 6
Processor Speed: 2259 MHz
Vendor ID: 8086
Device ID: 2A42
Device Revision: 07
* Accelerator Information *
Accelerator in Use: Mobile Intel(R) 4 Series Express Chipset Family
Video BIOS: 1629.0
Current Graphics Mode: 1600 by 900
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 3.55
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: Not Available
Vertical: Not Available
Monitor Supported Modes:
1600 by 900 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4D D9 FA 06 09 00 00 00
00 0C 01 03 80 00 00 FF 2F 00 00 A0 57 49 9B 26
10 48 4F 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 95 22 40 20 60 84 05 30 14 12
21 00 00 00 00 00 00 18 00 00 00 FD 00 00 3C 00
E6 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AA
* Other names and brands are the property of their respective owners. *
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Accelerator in Use: Intel(R) Graphics Media Accelerator HD
Video BIOS: 1994.0
Current Graphics Mode: 1366 by 768
Gamma Value: 2.2
Maximum Image Size:
Horizontal: 13.39 inches
Vertical: 07.48 inches
1366 by 768 (60 Hz)
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 06 AF EC 20 00 00 00 00
01 12 01 03 80 22 13 78 0A 57 55 9C 5A 54 9D 26
1A 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 26 1B 56 47 50 00 26 30 30 20
34 00 58 C1 10 00 00 18 00 00 00 0F 00 00 00 00
00 00 00 00 00 00 00 00 00 20 00 00 00 FE 00 41
55 4F 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
00 42 31 35 36 58 57 30 32 20 56 30 20 0A 00 2E
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I installed a clean copy of Windows 7 on my laptop and Sony doesn't wanna support my laptop with Win7 , so drivers can only come from windows update or intel's web-site. (the drivers freeze my screen no matter where I get them from - winUpdate or Intel's), so I don't think it's a costumization issue.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I don't think I'll be able to get you all that system information. I don't have any intel drivers to "roll back" to that actaully work (Hence, the need for me to buy a video card). Is there some kind tool/utility I can run that gives the same info without installing the drivers?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
So if it is Vendor customizations... why do drivers earlier than 2086 work just fine? The same "Vendor Customizations" exist there.. I really hope someone is willing to dig a little deeper into this issue. Intel was able to work around all these "Vendor custimizations" before driver 2086 just fine.
-Devoh
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I have the Advent Roma 2000.
Memory: 3GB
OS: Windows 7 (32bit)
I am currently on my PC but will run the diagnostic as soon as I can get on the laptop.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Video BIOS: 1994.0
Gamma Value: 2.2
Maximum Image Size:
1366 by 768 (60 Hz)
Raw EDID:
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Intel® Graphics Media Accelerator HD (Core i3)
Report Time[hr:mm:ss]: 17:51:30
Driver Version: 8.15.10.2040
Physical Memory: 3764 MB
Maximum Graphics Memory: 1754 MB
Graphics Memory in Use: 16 MB
Processor: Intel64 Family 6 Model 37 Stepping 2
Processor Speed: 2127 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 12
Video BIOS: 1994.0
Gamma Value: 2.2
Maximum Image Size:
1366 by 768 (60 Hz)
Raw EDID:
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
System: Acer Aspire 5740-5780 Notebook
All drivers newer than 8.15.10.2021 result in blank screen during installation. Rebooting results in Windows logo remaining on the screen forever. The system is still "operational" ... I can hear the log-on sound, but nothing on screen except the logo. Acer only offers the original release driver (typical for them). Unfortunately, newest Intel drivers fix a lot of bugs, as well supporting Flash H264 acceleration. Not the mention, its being pushed by Windows Update.
Here is a system report: (I can provide even more detailed info if necessary)
Report Time[hr:mm:ss]: 23:1:23
Graphics Memory in Use: 15 MB
Vendor ID: 8086
Device ID: 0046
Device Revision: 12
Video BIOS: 1994.0
Gamma Value: 2.2
Maximum Image Size:
1366 by 768 (60 Hz)
Raw EDID:
System Info:
Computer:
Computer Type ACPI x64-based PC (Mobile)
Operating System Microsoft Windows 7 Ultimate
OS Service Pack -
Internet Explorer 8.0.7600.16385
Motherboard:
CPU Type DualCore Intel Core i3 330M, 2133 MHz (16 x 133)
Motherboard Name Acer Aspire 5740
Motherboard Chipset Intel Ibex Peak-M HM55, Intel Ironlake-M
System Memory 3764 MB (DDR3-1066 DDR3 SDRAM)
DIMM1: Elpida EBJ21UE8BDS0-AE-F 2 GB DDR3-1066 DDR3 SDRAM (7-7-7-20 @ 533 MHz) (6-6-6-18 @ 457 MHz)
DIMM3: Elpida EBJ21UE8BDS0-AE-F 2 GB DDR3-1066 DDR3 SDRAM (7-7-7-20 @ 533 MHz) (6-6-6-18 @ 457 MHz)
BIOS Type Phoenix (03/18/10)
Display:
Video Adapter Intel(R) Graphics Media Accelerator HD (1796354 KB)
3D Accelerator Intel GMA HD
Monitor AU Optronics B156XW02 V0 [15.6" LCD]
Multimedia:
Audio Adapter Intel HDMI @ Intel Ibex Peak PCH - High Definition Audio Controller [B-2]
Audio Adapter Realtek ALC272 @ Intel Ibex Peak PCH - High Definition Audio Controller [B-2]
Storage:
IDE Controller Intel(R) 5 Series 4 Port SATA AHCI Controller
Input:
Keyboard Standard PS/2 Keyboard
Mouse Synaptics PS/2 Port TouchPad
Network:
Primary IP Address [edited]
Primary MAC Address [edited]
Network Adapter Atheros AR5B93 Wireless Network Adapter
Network Adapter Broadcom NetLink (TM) Gigabit Ethernet
Modem Agere Systems HDA Modem
Peripherals:
Printer \\PRIMARY\Samsung ML-2510 Series
Printer Fax
Printer Microsoft XPS Document Writer
USB2 Controller Intel Ibex Peak PCH - USB 2.0 EHCI Controller 1 [B-2]
USB2 Controller Intel Ibex Peak PCH - USB 2.0 EHCI Controller 2 [B-2]
USB Device Gener...
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
ACER ASPIRE 5740-5255
Report Date: 4/21/2010
Report Time[hr:mm:ss]: 12:51:18
Driver Version: 8.15.10.1995
MB Processor: Intel64 Family 6 Model 37 Stepping 2
Vendor ID: 8086
Device ID: 0046
Device Revision: 12
Video BIOS: 1994.0
Monitor Display Type: Digital
Gamma Value: 2.2
Maximum Image Size: Horizontal: 13.39 inches Vertical: 07.48 inches
Monitor Supported Modes: 1366 by 768 (60 Hz)
Raw EDID:
0 ff ff ff ff ff ff 0 6 af ec 20 0 0 0 0 1 12 1 3 80 22 13 78 a 57 55 9c 5a 54 9d 26 1a 50 54 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 26 1b 56 47 50 0 26 30 30 20 34 0 58 c1 10 0 0 18 0 0 0 f 0 0 0 0 0 0 0 0 0 0 0 0 0 20 0 0 0 fe 0 41 55 4f a 20 20 20 20 20 20 20 20 20 0 0 0 fe 0 42 31 35 36 58 57 30 32 20 56 30 20 a 0 0
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Acer Aspire 5740
Report Date: 4/22/2010
Report Time[hr:mm:ss]: 15:5:5
Graphics Memory in Use: 20 MB
Vendor ID: 8086
Device ID: 0046
Device Revision: 12
Video BIOS: 1994.0
Gamma Value: 2.2
Maximum Image Size:
1366 by 768 (60 Hz)
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thanks everyone for the feedback and system information. We are continuing to investigate the issue and hopefull will have more information soon. Stay tuned.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
ello! I have the same problem. My notebook is a acer 5740-5255 with core i3 processor. I have a friend that have the same laptop but with core i5 processorm and he dont have this issue... He instal the last drivers and run fine... I think the problem is in driver with incompatibility in the i3 processors. This is very shamefull to intel... Please Intel fix this issue fastly...
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
It does not have anything to do with the Core i3 processors. The issue is also occurring on previous chipset that do not use the core i3 processors. Regardless,, the issue is being investigated.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
This is the system config BEFORE I updated the graphics driver. Notice the Driver Version: 8.15.10.1749.
Had to fall back on the system restore to remove the updated driver.
Will appreciate a quick fix!
System Information
Time of this report: 4/28/2010, 17:56:25
Machine name: VK-VAIO
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
Language: English (Regional Setting: English)
System Manufacturer: Sony Corporation
System Model: VGN-SR25L_B
BIOS: BIOS Date: 06/04/08 14:30:19 Ver: 08.00.10
Processor: Intel(R) Core(TM)2 Duo CPU P8400 @ 2.26GHz (2 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 2910MB RAM
Page File: 843MB used, 4976MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
Display Devices
Card name: Mobile Intel(R) 45 Express Chipset Family (Microsoft Corporation - WDDM 1.1)
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_9033104D&REV_07
Display Memory: 1327 MB
Dedicated Memory: 128 MB
Shared Memory: 1199 MB
Current Mode: 1280 x 800 (32 bit) (59Hz)
Monitor Name: ?????????
Monitor Model: unknown
Monitor Id: MS_0040
Native Mode: 1280 x 800(p) (59.947Hz)
Output Type: Internal
Driver Name: igdumd32.dll,igd10umd32.dll
Driver File Version: 8.15.0010.1749 (English)
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 7/13/2009 21:15:31, 3805184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-2875-39B0A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x9033104D
Revision ID: 0x0007
Driver Strong Name: igdlh.inf:Intel.Mfg.NTx86...1:iCNT0:8.15.10.1749:pci\ven_8086&dev_2a42
Rank Of Driver: 00EC2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I am having the same issues with a brand new system. After initial setup I downloaded and installed all updates. All went well until
it came time to install the Graphics Media Accelerator HD driver update. Then the dreaded balck/blank scrren others have been reporting. I was able to finally roll back the driver and have a working system. The problem has been isolated to the Graphics Card update installation.
Acer Aspire 5740-6491
i5 Core 430M
Windows 7 x64 bit
4 gigs of ram
Driver Date 11/6/09
Driver Version 8.15.10.1995
Intel® Graphics Media Accelerator HD (Core i5)
Report Date: 5/1/2010
Report Time[hr:mm:ss]: 13:16:30
Graphics Memory in Use: 32 MB
Processor Speed: 2260 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 12
Video BIOS: 1890.3
Gamma Value: 2.2
Maximum Image Size:
1366 by 768 (60 Hz)
Raw EDID:
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I can not install driver 15.17.3.2104 (BSOD after installing), so there is no "Intel Graphics and Media Control Panel", but I can describe it manually:
Laptop: Acer Aspire 3810TG
OS: Windows 7 Home Premium x86
Attempt to install the driver version: 8.15.10.2104
Actually installed version (using OS default): 8.15.10.1749
Phisical Memory: 4 Gb
Processor: Intel Core 2 Solo U3500 1.4GHz
What else is needed?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Ok, it's been almost two months now Anyone at Intel is working on this? I had a lot of people calling me asking to "fix" their videos...
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
