- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
In graphic options of Blender can be selected next options:
1. "none" - default Blender behavior with GPU
2. "oneAPI" - for our case, as each GPU maker, with "Embree GPU" check.
Next step - set Cycles on GPU mode. And if select a first options - it's starts to render immediately, but if second - loading around 15 or more seconds.
Why oneAPI - that native for Arc - loads so much slower than Blender default?
CPU: 12th Gen Intel(R) Core(TM) i5-12400F 2.50 GHz
RAM: 32,0 Gb
GPU: Intel Arc A770 16 Gb
OS: Windows 10 2H22 build 19045.2965
Driver version: 31.0.101.4972
Motherboard: MSI PRO-B660M-P-DDR4
BIOS: 7D24v2D
ReBar: on
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Roflosaur
Thank you for posting on the Intel Communities.
Did you test this on the latest version of Blender? We would like to know whether this 15-second loading time is only happening at the very beginning before the render starts or if it affects the overall time for the render to finish completely compared to the "note" option.
If possible share a short video showing the issue and a small sample file in case we need to test the app.
Hugo O.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Roflosaur
We would appreciate it if you could share with us the information we requested in our previous so we can continue to help you with this issue. We know it is important to have your apps working properly and are more than willing to help you.
Hugo O.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Roflosaur
We unfortunately did not receive the information we requested to help you with this issue, If you are still experiencing problems when using Blender feel free to open a new post.
Hugo O.
