22866 Discussions
Display Driver has stopped responding and has recovered
Hi. I know this question has been asked many times, but many are unanswered. I have a Dell Inspiron 1545, Window 7 64 bit. Just yesterday, my laptop kept blacking out, freezes and then unfreeze and this message would pop up saying, "Display driver stopped responding and has recovered. Display driver Intel Graphics Accelerator Drivers for Windows XP(R) stopped responding and has successfully recovered." It keeps happening around every 15-30 minutes. Sometimes, it totally blacks out. Other times, it unfreeze but the windows are blank. Someone please help me. The display adapter I have is Mobile Intel (R) 4 Series Express Chipset Family." Some people said online to update it and that might fix the problem. I went to the Intel website and updated the lastest one given, but the problem is still here. I've restored my laptop to a certain restore point, but still did not solve the problem. Suggestions and ideas? Thank you a head of time.
Hello Nic,
I, too, have the same problem as the others. So far, this has only happened while playing a specific game.
The message I get refers to the Intel Graphics for Windows XP, whereas I am running Windows 7 64-Bit.
I have provided you with the DXDIAG Report below. In previous posts, you mentioned that a current driver would need to be uninstalled before a possible new(er) one is installed.. Is that done through Device Manager -> Driver Properties -> Uninstall Driver?
I 'think' I have the most updated OEM Drivers, but I am not 100% certain.
I appreciate any assistance you may be able to provide with this matter.
System Information
Time of this report: 2/5/2013, 18:27:23
Machine name: SAHIL-SHAH-PC
Operating System: Windows 7 Professional 64-bit (6.1, Build 7600) (7600.win7_gdr.120830-0334)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron N4010
BIOS: Ver 1.00 BIOS A13 PARTTBL
Processor: Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz (4 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 3892MB RAM
Page File: 1695MB used, 6087MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics (Core i3)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_04561028&REV_18
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO183C
Native Mode: 1366 x 768(p) (60.098Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.2104 (English)
Driver Version: 8.15.10.2104
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 3/31/2010 22:47:00, 6534144 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4306-11CF-A07B-5C24B8C2C535}
Vendor ID: 0x8086
Device ID: 0x0046
SubSys ID: 0x04561028
Revision ID: 0x0018
Driver Strong Name: oem7.inf:Intel.Mfg.NTamd64:iILKM0:8.15.10.2104:pci\ven_8086&dev_0046&subsys_04561028
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Fr...
Hi Nic,
The link above led to an installer that only installed an Intel Turbo Boost. It has not, however, stopped the driver from crashing and recovering. Any other suggestions?
NICHOLAS_F_Intel
Hmm.. that link should have downloaded the driver, at least that's what that particular download is for! I would contact Dell* and see if they can provide you the driver download for that file since their website isn't doing it properly. It's for driver version 8.15.10.2345.
In the meantime, you can try out download for it and see if it fixes your issue as well. Keep in mind though, this is an Intel® generic driver, and you may not have full functionality with it. Let me know how it goes; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21776&lang=eng Download Center
-Nic
I tried the newest download you told me to try and it when I try to install it it says it's not the right one for my computer.
nic,
I have the same problem with a twist. My laptop has dual graphics, an Intel integrated graphics card and an nVidia discrete card for power savings. The graphics card used changes depending on the global program and power settings. I'm having the same "Intel graphics card stopped responding and recovered" error message at times, even when I'm using programs I've set for nVidia card such as Sketchup and Navisworks Freedom. I've downloaded the latest driver from Intel website last week, but it has not helped with the problem. Below is my DxDiag report.
Thanks in advance.
System Information
Time of this report: 2/7/2013, 09:59:20
Machine name: IGIN12
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
System Manufacturer: LENOVO
System Model: 427638U
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7-2720QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
Memory: 8192MB RAM
Available OS Memory: 8076MB RAM
Page File: 4904MB used, 11243MB available
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Devices
Card name: Intel(R) HD Graphics 3000
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_21D117AA&REV_09
Display Memory: 1700 MB
Dedicated Memory: 2014 MB
Shared Memory: 3781 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor Name: ThinkPad Display 1600x900
Monitor Id: LEN40B1
Native Mode: 1600 x 900(p) (59.990Hz)
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2932 (English)
Driver Version: 9.17.10.2932
DDI Version: 11
Driver Date/Size: 12/12/2012 16:42:36, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4266-11CF-9051-DD01B7C2C535}
Vendor ID: 0x10DE
Device ID: 0x0DFA
SubSys ID: 0x21D117AA
Revision ID: 0x00A1
Driver Strong Name: oem55.inf:Intel.Mfg.NTamd64:iSNBM0:9.17.10.2932:pci\ven_8086&dev_0126
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/O...
NICHOLAS_F_Intel
@sabrina: What's the exact error message? Can you provide a screenshot of it please?
@Ihsan: Hi Ihsan, thanks for providing that information. I just checked your OEM's support site for your product, and it doesn't appear that they provide Intel® driver support for graphics. However, your dxdiag shows that you're using the default BIOS that came on the system, perhaps an update will resolve the issue. Here's a link to the BIOS installer; http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/8buj19us.exe http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/8buj19us.exe
Let me know if that works for you.
-Nic
Thanks Nic,
I'll see if it helps and will let you know.
And I have the latest driver from Toshiba. None of the drivers that I have been able to install has made a difference. At one time there was a generic driver that worked a little better, but some things wouldn't run. My Uncle thought that wiping everything out and doing a clean install of 7 might work. When I changed from Vista to 7 I had the upgrade disk and installed it by all recommended settings. Though he has never heard of the problems that we all are having.
Hello Nic,
Unfortunately, updating the BIOS did not really help. I'm still getting "graphics driver stopped to response and recovered" messages, albeit not as frequent. I'll see if there is a way to disable the integrated graphics and make the discrete GPU the go-to graphics card.
thanks again for the help.
NICHOLAS_F_Intel
@sabrina: In order to install that driver, you'll need to uninstall the one you currently have. To do that, open Device Manager -> Display Adapters -> Right click your current driver and select "Uninstall" - if/when prompted, choose to delete the files so that it doesn't re-install them immediately afterwards (automatically). Then try running the driver install again.
@Ihsan: I would contact your OEM to see if they provide a switchable graphics driver. If you have a system running both a discrete card & onboard, you'll be best served by one of these.
-Nic
Hello nic please help me i have the same problem
my dxdiag is:
System Information
Time of this report: 3/1/2013, 20:42:27
Machine name: HOME-PC
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
System Manufacturer: SAMSUNG ELECTRONICS CO., LTD.
System Model: R519/R719
BIOS: Phoenix SecureCore(tm) NB Version 09CI.M060.20100401.JIP
Processor: Celeron(R) Dual-Core CPU T3100 @ 1.90GHz (2 CPUs), ~1.9GHz
Memory: 1536MB RAM
Available OS Memory: 1496MB RAM
Page File: 1597MB used, 1395MB available
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_C059144D&REV_09
Display Memory: 556 MB
Shared Memory: 492 MB
Monitor Id: SEC5441
Native Mode: 1366 x 768(p) (60.023Hz)
Driver Name: igdumdx32.dll,igd10umd32.dll
Driver File Version: 8.15.0010.2869 (English)
Driver Version: 8.15.10.2869
DDI Version: 10
Driver Date/Size: 11/13/2012 23:43:37, 571904 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-C87C-53E0A9C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0xC059144D
Revision ID: 0x0009
Driver Strong Name: oem6.inf:IntelGfx.NTx86.6.0:iCNT0:8.15.10.2869:pci\ven_8086&dev_2a42
Rank Of Driver: 00E62001
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX Video...
@Orcun
nic helped me on this.I am not getting any problem now..! you need to install latest version of display drivers.
Hi, nic. I have the same prob with my computer. At first, the display driver stopped responding and recovered, but in this few days, my computer kept freeze and unfreeze then came out a blue screen. Please provide some solution. TQ
Hi nic, you've been a Jesus so far, thank you so much on behalf of computer-illiterate man kind! I hope you can help me too: same problem, but only when attempting to play games.
Here's my dxdiag report:
System Information
Time of this report: 2/27/2013, 02:45:51
Machine name: BENDRAS-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
System Manufacturer: ASUSTeK Computer Inc.
System Model: K52Jc
BIOS: BIOS Date: 10/30/09 15:13:23 Ver: 08.00.10
Processor: Intel(R) Core(TM) i3 CPU M 350 @ 2.27GHz (4 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 3884MB RAM
Page File: 2913MB used, 6795MB available
User DPI Setting: 96 DPI (100 percent)
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_1C221043&REV_12
Monitor Id: CMO1571
Native Mode: 1366 x 768(p) (60.046Hz)
Driver File Version: 8.15.0010.2253 (English)
Driver Version: 8.15.10.2253
DDI Version: 10
Driver Date/Size: 11/29/2010 05:23:15, 7428608 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4306-11CF-3E7B-283CB2C2C535}
Vendor ID: 0x8086
Device ID: 0x0046
SubSys ID: 0x1C221043
Revision ID: 0x0012
Driver Strong Name: oem3.inf:Intel.Mfg.NTamd64:iILKM0:8.15.10.2253:pci\ven_8086&dev_0046
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IM...
NICHOLAS_F_Intel
Hi Donatas,
First thing, I'm not sure where you got your driver, but you might consider either using the latest Asus* driver for your model, located here under 'VGA -> Intel' http://www.asus.com/Notebooks_Ultrabooks/K52JC/# support_Download_30 ASUS - - ASUS K52JC
Or using our latest driver, provided here; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21776&lang=eng Download Center
Secondly, you might also see benefit from upgrading your BIOS. You're currently using a version dated for 2010, and they have one available (version 216) that was released in 2011. Also here under BIOS -> http://www.asus.com/Notebooks_Ultrabooks/K52JC/# support_Download_30 ASUS - - ASUS K52JC
Give those a try, and let me know if you need anything else.
-Nic
Hey Nic,
Unfortunately, this only helped partially (it occurs less often), however, I noticed a couple of things (don't know if related).
I remember updating my BIOS last year, but went on to BIOS itself to check. It reported the current platform as being 216, updated on 2012. But I re-updated it just to reassure myself. It did not show up on dxdiag though. So my BIOS isn't the problem.
I tried your latest driver first (15.22.57.64.2827), it still crashed. Went on to downgrade to the one provided by ASUS (V8.15.10.2202), same thing. However, now it does not tell that the driver had stopped responding and recovered, but it still behaves as if it did: when I launch the game, it flashes a couple of times as if trying to re-start. If I don't close the program, I eventually get a BSOD. I can attach the minidump files created after each BSOD if needed.
I am currently using the driver provided by my manufacturer and it is up-to-date. Any ideas?
Thanks a lot,
Donatas.
NICHOLAS_F_Intel
@Carl: Can you provide the exact model name for your system?
@Donatas: Go ahead and attack one of the minidump files, I'll take a look at it.
@kurnia rahman: Try out this driver, let me know how it goes. It might report that its an earlier driver version than the one being used, just ignore the message if it does; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18496&lang=eng Download Center
-Nic
Nic,
I have a Lenovo Thinkpad T420 type 4236-C42
NICHOLAS_F_Intel
Thanks Carl - go ahead and try your OEM's latest driver for the system (.2843) - http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/83d637ww.exe http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/83d637ww.exe
If you get a message that says "this driver is older than the installed one", ignore it and install it anyways. Let me know how it goes!
-Nic
Nic,
I did that, still having the same problems.
