22945 Discussions
Display Driver has stopped responding and has recovered
Hi. I know this question has been asked many times, but many are unanswered. I have a Dell Inspiron 1545, Window 7 64 bit. Just yesterday, my laptop kept blacking out, freezes and then unfreeze and this message would pop up saying, "Display driver stopped responding and has recovered. Display driver Intel Graphics Accelerator Drivers for Windows XP(R) stopped responding and has successfully recovered." It keeps happening around every 15-30 minutes. Sometimes, it totally blacks out. Other times, it unfreeze but the windows are blank. Someone please help me. The display adapter I have is Mobile Intel (R) 4 Series Express Chipset Family." Some people said online to update it and that might fix the problem. I went to the Intel website and updated the lastest one given, but the problem is still here. I've restored my laptop to a certain restore point, but still did not solve the problem. Suggestions and ideas? Thank you a head of time.
Hey nic,
here's the minidump file analyzed with WinDbg, not sure this is all I can get from it, hope this helps.
Thank you!!!!!!
Loading Dump File [C:\Windows\Minidump\031813-42089-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is: srv*
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18044.amd64fre.win7sp1_gdr.130104-1431
Machine Name:
Kernel base = 0xfffff800`02e5a000 PsLoadedModuleList = 0xfffff800`0309e670
Debug session time: Mon Mar 18 14:43:45.914 2013 (UTC + 0:00)
System Uptime: 0 days 20:55:51.976
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 116, {fffffa8006cbe010, fffff88006663370, 0, d}
Unable to load image \SystemRoot\system32\DRIVERS\igdkmd64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for igdkmd64.sys
*** ERROR: Module load completed but symbols could not be loaded for igdkmd64.sys
Probably caused by : igdkmd64.sys ( igdkmd64+29370 )
Followup: MachineOwner
3: kd> !analyze -v
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa8006cbe010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88006663370, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 000000000000000d, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
igdkmd64+29370
fffff880`06663370 4053 push rbx
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`061a8a58 fffff880`02f40000 : 00000000`00000116 fffffa80`06cbe010 fffff880`06663370 00000000`00000000 : nt!KeBugCheckEx
fffff880`061a8a60 fffff880`02f3fd87 : fffff880`06663370 fffffa80`06cbe010 fffffa80`045e84c0 fffffa80`082f9410 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`061a8aa0 fffff880`02e0ff07 : fffffa80`06cbe010 00000000`00000000 fffffa80`045e84c0 fffffa80`082f9410 : dxgkrnl!TdrIsRecoveryRequired+0x21f
fffff880`061a8ad0 fffff880`02e3dd5a : fffffa80`ffffffff 00000000`0049b36e fffff880`061a8c30 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`061a8bb0 fffff880`02e0b29e : fffffa80`082f9410 ffffffff`feced300 fffffa80`045e84c0 00000000`00000000 : dxgmms1!VidSchWaitForCompletionEvent+0x196
fffff880`061a8bf0 fffff880`02e37e7a : 00000000`00000000 fffffa80`045e84c0 00000000`00000080 fffffa80`082f9410 : dxgmms1!VidSchiScheduleCommandToRun+0x1b2
fffff880`061a8d00 fffff800`0317034a : 00000000`fffffc32 fffffa80`081b1b50 fffffa80`03dec990 fffffa80`081b1b50 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`061a8d40 fffff800`02ec0946 : fffff880`031d5180 fffffa80`081b1b50 fffff880`031dffc0 00000043`74028000 : nt!PspSystemThreadStartup+0x5a
<str...
NICHOLAS_F_Intel
Thanks for the info Donatas!
It appears there is either an issue with your system and the driver, or the specific installation of the driver. I would recommend doing the following:
1. Uninstall the display driver (delete all associated files if/when prompted)
2. Restart computer
3. Re-install the latest Asus* driver (you can try doing this with our driver as well)
Something might have gone wrong during driver installation, or perhaps some existing files and/or older drivers caused a conflict with the installation. Let me know how it goes!
-Nic
NICHOLAS_F_Intel
Carl - can you check your C:\Windows\Minidump or C:\Windows\Memory for any minidump files (.dmp) to see if your system is generating them when the driver crashes? I'm currently unsure if the system creates them for our driver, so let me know if you can find some or not.
-Nic
Nic,
I checked my Minidump folder, and it is empty
Hi nic, i have install the driver you recommended but it's still have the same problem
NICHOLAS_F_Intel
@kurnia: The driver your OEM has for you (.2117) is the same as our latest for your hardware (also .2117). In the original DxDiag you provided, you had this driver installed - do you know if it was the one from your OEM, us, or just one that came default on the system? Additionally, if you go into the Power settings of the Intel® Graphics Control Panel (Ctrl + Alt + F12), what setting is it currently on? If not already on it, can you set it to "Maximum Performance" and tell me if the issue still occurs?
@Carl: Can you go into the Power settings of the Intel® Graphics Control Panel (Ctrl + Alt + F12), what setting is it currently on? If not already on it, can you set it to "Maximum Performance" and tell me if the issue still occurs?
-Nic
Nic,
If I open that control panel, the driver still crashes.
Nic,
I open it again, and both the driver, and that GfxUI crash at the same time.
NICHOLAS_F_Intel
Let me know if I've already suggested this to you;
1. Completely uninstall the driver via Device Manager (delete all associated files)
2. Restart the system
3. Re-install the driver (.zip version) using the have-disk method
Link to .zip driver: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22376&lang=eng Download Center
Link to have-disk instructions: http://www.intel.com/support/graphics/sb/CS-033915.htm How to update graphics driver for Microsoft Windows 7*
Let me know if you need help with any of these steps, and let me know how it goes.
-Nic
Nic,
I did what you said. It still crashes.
Hi Nic,
thanks for the help, almost my game can play now.. but there is only 1 game that cannot played because the same problem, what i must do now?
NICHOLAS_F_Intel
@kurnia: There is another 3150 driver you can try, here; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19494&lang=eng Download Center
let me know if this fixes the problem.
@Carl: You can also change the power settings of your system in the Windows* control panel under Power Settings. Can you change that to max performance, and then see if you are still crashing?
-Nic
Nic
the problem is still not fixed with the game...
Hi, I'm having the same problem.
System Information
Time of this report: 3/22/2013, 16:22:27
Machine name: DEJI-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire 5738
BIOS: Ver 1.00PARTTBL
Processor: Pentium(R) Dual-Core CPU T4300 @ 2.10GHz (2 CPUs), ~2.1GHz
Memory: 3072MB RAM
Available OS Memory: 3000MB RAM
Page File: 1958MB used, 4041MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_02051025&REV_09
Display Memory: 1308 MB
Dedicated Memory: 64 MB
Shared Memory: 1244 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: LP156WH2-TLE1
Monitor Id: LGDCF01
Native Mode: 1366 x 768(p) (59.973Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.1892 (English)
Driver Version: 8.15.10.1892
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 9/2/2009 18:54:16, 5617664 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-F174-0F22A9C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x02051025
Revision ID: 0x0009
Driver Strong Name: oem28.inf:Intel.Mfg.NTamd64:iCNT0:8.15.10.1892:pci\ven_8086&dev_2a42&subsys_02051025
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: F...
NICHOLAS_F_Intel
@Deji: Try this driver out; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167&lang=eng
@Everyone who still experiences the problem after updating their drivers; Can you please try updating your Microsoft* .NET Framework to the latest version?
If you are using Windows* 7: http://msdn.microsoft.com/netframework/cc378097 http://msdn.microsoft.com/netframework/cc378097
If you are using Windows* 8: http://www.microsoft.com/visualstudio/eng/downloads# d-net-45 Download | Microsoft Visual Studio 2012 (listed under Additional Downloads - .NET 4.5)
Let me know if this resolves your issue!
-Nic
hello nic! i would also like to ask for your help. i am experiencing the same problem "Display Driver has stopped responding and has successfully recovered". It will appear at about every 30 minutes or an hour. Please let me know what to do about it. as with others have been doing, i am attaching the dxdiag of my Acer 2930z laptop:
System Information
Time of this report: 3/22/2013, 22:40:00
Machine name: CAEDMONREY-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
System Model: Aspire 2930Z
BIOS: InsydeH2O Version V1.11
Processor: Intel(R) Pentium(R) Dual CPU T3200 @ 2.00GHz (2 CPUs), ~2.0GHz
Memory: 2048MB RAM
Available OS Memory: 1980MB RAM
Page File: 1706MB used, 2253MB available
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Devices
Card name: Mobile Intel(R) 45 Express Chipset Family (Microsoft Corporation - WDDM 1.1)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_01441025&REV_07
Display Memory: 798 MB
Shared Memory: 734 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor Model: unknown
Monitor Id: AUO3714
Native Mode: 1280 x 800(p) (60.002Hz)
Driver File Version: 8.15.0010.1749 (English)
Driver Version: 8.15.10.1749
DDI Version: 10
Driver Date/Size: 7/14/2009 04:41:07, 5437952 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-6902-11CF-4075-4E21A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x01441025
Revision ID: 0x0007
Driver Strong Name: igdlh.inf:Intel.Mfg.NTamd64...1:iCNT0:8.15.10.1749:pci\ven_8086&dev_2a42
Rank Of Driver: 00EC2001
<p style="font-s...
Thanks! It still does it occassionally, but it's a lot better now. Thank you
Nic,
I installed the .NET framework, still crashes
Hey Nic,
I've done everything you suggested, re-installed the drivers a few times, it still seems to report the driver malfunction (has stopped responding and recovered) causing black screen and a BSOD eventually. I took the advice and installed-updated .NET and that didn't help. Any ideas? Do you think it might be a hardware problem aswell like for Carl? Attaching my dxdiag for the last time, maybe there's something changed (sorry, not too literate in that :c )
System Information
Time of this report: 4/4/2013, 13:49:24
Machine name: BENDRAS-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
System Manufacturer: ASUSTeK Computer Inc.
System Model: K52Jc
BIOS: BIOS Date: 10/30/09 15:13:23 Ver: 08.00.10
Processor: Intel(R) Core(TM) i3 CPU M 350 @ 2.27GHz (4 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 3884MB RAM
Page File: 3480MB used, 6228MB available
User DPI Setting: 96 DPI (100 percent)
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Devices
Card name: Intel(R) HD Graphics
Chip type: Intel(R) HD Graphics (Core i3)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_14321043&REV_12
Display Memory: 1696 MB
Shared Memory: 1632 MB
Monitor Id: CMO1571
Native Mode: 1366 x 768(p) (60.046Hz)
Driver File Version: 8.15.0010.2827 (English)
Driver Version: 8.15.10.2827
DDI Version: 10
Driver Date/Size: 8/9/2012 15:21:16, 8314368 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4306-11CF-7D76-3F34AFC2C435}
Vendor ID: 0x8086
Device ID: 0x0046
SubSys ID: 0x14321043
Revision ID: 0x0012
Driver Strong Name: oem28.inf:IntelGfx.NTamd64.6.0:iILKM0:8.15.10.2827:pci\ven_8086&dev_0046
Rank Of Driver: 00E62001
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: For...
NICHOLAS_F_Intel
@Wildan: Can you access the link now?
@kurnia: Can you provide me an exact location on that facebook page to look at? Also, is there a different source you could provide?
@Donatas: There's a new driver you can try out firstly; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521&lang=eng
Secondly, if you're system is BSOD'ing, it is definitely not software. You could be overheating, or have an overall hardware failure problem. I would contact your OEM and get it checked out.
