공지
22754 토론
Driver and Support Assistant Not Working On Windows 10
geo
초급자
13,798 조회수
My Support assistant isn't working.  I receive a notification that I have driver updates available.  When I go to the intel page, it says I need to download the app again and then it "unistalls" the app.  It work ok for a few months, but this is a recent problem
0 포인트
1 솔루션
Sebastian_M_Intel
중재자
13,755 조회수
Hello geo,
Thank you for posting on the Intel® communities.
Please try the following steps and let us know about the outcome:
1. What is the browser that you are using? Make sure that you are using the validated browsers: Chrome, Firefox, or Edge* (version 44.17763/18.17763 or newer browsers)
2. Uninstall the  existing Intel® Driver & Support Assistant (Intel® DSA) from Apps and Features:
  • Click Start
  • Open Control Panel
  • Select Programs
  • Select Programs and Features
  • From the list that displays, click Intel® Driver & Support Assistant
  • Click Uninstall
  • A new window opens that offers to uninstall the program.
3. Remove any remaining files from the Intel® DSA in the system using the Uninstaller tool
4. Download and reinstall the latest Intel® DSA version, run the installer as administrator (right-click on the icon and choose Run as Administrator).
5. In case the above does not work, please provide the Intel® DSA logs for the tool and uninstaller:
Intel® DSA:
Note: In case you do not see the "ProgramData" folder click on the upper tab "View" and check the box "Hidden items".
Intel® DSA Uninstaller tool:
  • Use the Uninstaller tool again to uninstall the remaining files for the Intel® DSA.
  • Press Windows key + E (File explorer Windows will be opened with this key combination).
  • Click on "This PC."
  • Look for: Disk C:\, on the search bar, type: "DSAUninstaller.log".
  • Take the logs, copy and paste them into a folder and send them to us.
Sebastian M
Intel Customer Support Technician
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
원본 게시물의 솔루션 보기
0 포인트
10 응답
AlHill
수퍼 사용자
13,795 조회수
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
0 포인트
geo
초급자
13,781 조회수
Hi AlHill, thanks for the reply.  I've attached the file
0 포인트
Lele33
초급자
12,248 조회수
Hello, i have the same problem. So i did the same. Can you help me please ?
0 포인트
Sebastian_M_Intel
중재자
13,756 조회수
Hello geo,
  • Click Start
  • Select Programs
  • Click Uninstall
Intel® DSA:
Sebastian M
0 포인트
geo
초급자
13,743 조회수
Thanks Seb, worked a treat 😀
BTW,  I was using Brave as my browser and didn't have any issues previously.
0 포인트
whoamiindeed
초급자
13,431 조회수
Sebastian,  I've always used Brave (chromium) as my default browser, and Intel Support Assistant worked on it fine until this year.  Now it doesn't, which - I guess I understand, since it's not directly Chrome, and certainly isn't Firefox or Edge.  But I don't understand why Brave did used to work, and stopped.  ?
Thanks, though, switched to Chrome and it worked much better.
0 포인트
matiasch
초급자
12,957 조회수
Hi. Where I can find the "Unistaller tool"? The page isn´t working. ("We are sorry. The page is temporalily unaivailable..").
0 포인트
n_scott_pearson
수퍼 사용자
12,937 조회수
This display ordering makes this almost humorous. @matiasch is saying in the entry above that he can't get to the tool and the entry below is @Sebastian_M_Intel saying glad you resolved it. Of course, they are posts 6 months apart and have nothing to do with each other. Why? Because @matiasch has hijacked this conversation. @matiasch - It doesn't matter if you believe that you have the same problem; set up your own conversation. No arguing. We will answer you there...
0 포인트
Sebastian_M_Intel
중재자
13,735 조회수
Hello geo,
Thank you for your reply.
I am glad to hear that your Intel® DSA is now working. Based on that, we will proceed to close this inquiry; if you have any additional questions, please submit a new thread and we will gladly assist you.
Sebastian M
0 포인트
Lele33
초급자
11,981 조회수
Hello, I have the same problem. Can you help me ?
0 포인트
응답
