При запуске игры MINECRAFT запускается на Интел Графике а видео карта пустует, помогает только отключение самой видеокарты Интел. В самом Инвидео стоит приорете на запуск с видеокарты но в данной игре графика Интел почему то берет приоритет.
Is this a laptop? If so, talk to your laptop vendor. They are responsible for the drivers for your laptop's graphics.
You have a laptop with dual graphics, correct? Are you using the drivers provided by the laptop manufacturer? If not, you should.
Doc
Да использую все драйвера от производителя. И обновленный BIOS
Download, run, and ATTACH the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an intel support engineer can assist you.
Doc
Более подробнее тут : https://ru-minecraft.ru/forum/showtopic-18579/ . Это русский фоурм по Minecraft
Hello ASeki1,
Thank you for posting on this Intel Community.
To better assist you, please attach the missing information from the Template for submitting a Graphics bug
DxDiag* report:
1. Press WinLogo key + R.
2. Type “dxdiag” and press Enter.
3. Click on "Save All Information" and save it on your computer.
4. Attach the report to this thread.
Wanner G.
A Contingent Worker at Intel
Hello ASeki1,
Thank you for your response.
We launched the game on a system with hybrid graphics, Intel® HD Graphics 630 + discrete graphics. We did not experience the behavior reported on this thread, which means that the problem you are having is not a driver issue.
Recommended steps:
1. With the Intel® HD Graphics enabled, try enabling/disabling NVIDIA* hardware acceleration and check the performance of the system (if applicable).
Additional information:
2. Where did you download the game from?
3. Were you able to launch the game with both integrated and discrete graphics enabled before?
Note: Our support is only provided in English. We may not be able to translate screenshots/files attached to the thread. To better assist you, we use a translation tool embedded on this Intel® Community.
Wanner G.
Hello ASeki1,
If you need further assistance, please let us know. We will be glad to help you.
Wanner G.
Hello ASeki1,
Were you able to contact your Original Equipment Manufacturer (OEM) to know if there is a way to disable/enable hardware acceleration?
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
