- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi, So far Honkai star rail is the only game on my computer that causes a hard freeze and i have to manually reboot the computer.
So far any graphics setting higher than "low" causes the computer to Freeze.
It can happen within 5 min or 2 hours, but most frequently when any battle occurs.
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello chronion,
In order for me to better investigate the issue, please provide the following information below:
- Does the issue happen the first time that you play the game? If not, have you made any changes before the issue occurred?
- What troubleshooting steps have you already tried? This will help me to avoid providing the same troubleshooting steps to you.
- Have you already performed a clean installation of drivers using DDU? If not, please try it, then install our latest driver: 32.0.101.6557/32.0.101.6262.
- What is the brand and model of your power supply? This is to check if your PSU meets the Arc graphics requirements.
- Please provide a video of the game showing how and when the issue occurred. This will be used for game replication in our lab.
- Kindly generate an SSU report to help me further analyze your system specifications and configurations. Please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send me the generated SSU.txt file.
Carmona A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi
1. Yes it happened the first time i played the game, i got a new computer.
2. I've re-installed the game, manually upgraded the motherboard to the latest patch, installed the latest drivers for the GPU, checked CPU and GPU temperature.
3. I have not yet performed a clean install using DDU, i will have to try that. So i tried to perform a clean install with DDU, found a guide online and it broke everything, for some reason i could not start the PC in safemode and i was stuck in the login screen without being able to move on, there was no guide to solve my problem since every guide i found was after the login screen to windowns. so i did a re-install of everything.
4. PSU is a Seasonic Vertex GX 850W
5. I am not able to record a video since it will not be saved during the crash, i do have screenshoots of when the crash occurs, the Issue is mostly random, either in the overworld, in a fight or even just afk in the open world.
6. I've added the SSU file and screenshots of how it looks when the crash/freeze occurs.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello chronion,
Thank you for providing this information.
Could you please confirm if the following troubleshooting steps have been attempted?
- Check for game updates: Ensure that the game is updated to the latest version.
- Monitor GPU temperature: Overheating can cause the computer to freeze. Please ensure proper cooling to mitigate this issue.
- Check for background processes: Verify that there are no resource-intensive background processes running while playing the game.
If the issue persists after trying these steps, please create a new thread as this thread will no longer be monitored.
Jed G.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
