Hallo,
Intel® Arc™ &; Iris® Xe Grafik - WHQL - Windows* wird nicht installiert. Beim Klick auf "Installieren" oder "Alle Installieren" passiert nichts.
Dieser Treiber wird seit Wochen unter meinen Updates angezeigt. Es gab bis jetzt keinerlei Probleme mit allen anderen Updates.
MfG
Gunter Schaumburg
Hello GunterSchaumburg
I hope you are doing fine.
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
Hello GunterSchaumburg,
We would like to request further system details for your PC. Please, create a system report using the Intel®️ System Support Utility (Intel®️ SSU).
- Download the Intel SSU
- Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
- Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save."
To solve this problem, you can try the following:
- Please make sure you are using Chrome, Firefox, or Edge* (version 44.17763/18.17763 or newer) browsers.
- Option 1
- Open the add or remove the programs control panel from the Windows Start menu.
- Locate and select Intel® Driver & Support Assistant in the list of installed applications.
- Click or tap the Modify button.
- Accept the User Account Control prompt.
- Click or tap the Repair button to repair your Intel® DSA installation.
- Option 2
- Uninstall Intel® DSA via Control Panel.
- Restart the system.
- Download the latest version of Intel® Driver & Support Assistant.
Jean O.
Thanks for the information provided.
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Since the problem remains, we would like to recommend you try the following:
- If Intel® DSA will still not install or errors about missing files are seen, utilize Intel® DSA Uninstaller.
- If an error message This feature you are trying to use is on a network resource that is unavailable appears while installing the IDSA, proceed to step 4.
- Download the latest supported Visual C++ file using this link.
- Latest supported Visual C++ Redistributable downloads | Microsoft Learn
- Delete all the existing VC runtime.
- Re-install the latest supported Visual C++.
- Install the latest Intel® Driver & Support Assistant.
Jean O.
We hope you are doing fine.
Jean O.
Hugo O.
![](/skins/images/48A1642489FEF8D34D940AC6791CBDC2/responsive_peak/images/icon_anonymous_message.png)
