22680 토론
Intel Graphics 630 can't refresh @120hz on windows 10
Kurt_Dada
초급자
4,267 조회수
hi all,
I have two all in one computer and both have i5-7500 with intel graphics 630. On one  I run linux (zorin Os) I am able to set the display to refresh@120hz with resolution @1920x1080 and connect another monitor (Asus) and set it to 120hz via HDMI, same resolution.  The second one, I run windows 10 and I am not able to change the refresh rate to 120hz. It is fixed @60hz. I installed the latest intel driver but problem persists. From advanced settings I only get an option for 60hz at any resolution. I am out of ideas, and I can't find solutions anywhere or similar situation. That's about it, thanks.
0 포인트
7 응답
n_scott_pearson
수퍼 사용자
4,261 조회수
Have you tried creating a custom resolution in the Intel Graphics Command Center?
Please download and run the Intel System Support Utility for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
0 포인트
Kurt_Dada
초급자
4,255 조회수
hey thanks
I generated the text file and attached
0 포인트
WittyGoldfish
초급자
4,193 조회수
Effective and interesting post for reading
0 포인트
n_scott_pearson
수퍼 사용자
4,219 조회수
I am not seeing anything obvious in the report. You didn't say whether the two AIOs are the same model. It is possible that the display in this second AIO simply doesn't support a refresh rate higher than 60Hz. As I suggested, try creating a custom resolution entry and see if it will let you pick a refresh rate higher than 60Hz then.
0 포인트
Kurt_Dada
초급자
4,208 조회수
yes they are the same model. sorry for late reply, i installed the new driver from intel and now the computer is freezing a lot, i will try restore.
0 포인트
AndrewG_Intel
직원
4,140 조회수
Hello Kurt_Dada
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
0 포인트
AndrewG_Intel
직원
4,113 조회수
Hello Kurt_Dada
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
0 포인트
응답
