22668 ディスカッション
Intel HD 4000 freezes my computer
従業員
43,473件の閲覧回数
I have Windows 8 and Intel HD 4000 graphics. The driver version is 9.17.10.2867. When I try to play a game in full screen it freezes my whole computer. Does anyone else have this problem? And is there a way to fix it?
118 返答(返信)
VNeme
ビギナー
10,045件の閲覧回数
VNeme
ビギナー
10,045件の閲覧回数
The new update seems to have sorted it..so far so good!
entilza
新規コントリビューター I
10,045件の閲覧回数
The P8Z77-V LK BIOS on ASUS's site has also been updated to 0908. I will try this asap. Finally the website is working again.
従業員
10,036件の閲覧回数
Hello...everyone... I have an problem with my intel HD 4000...
But my problem is... I can run the game, but when i try to tun on Anti Aliasing it automaticly restart my laptop and the message that i get is YOUR COMPUTER RAN INTO A PROBLEM and i need to wait till they get the information to 100% about the problem and it restart my laptop...
I have Win 8 64 Bit...
Laptop i5 core 2.6Ghz 8 Gb ddr3 ram and my graphic card supports Anti Aliasing... plz help me...
従業員
10,036件の閲覧回数
  • Intel Core i5 3317U 2.6 GHz
  • 8 GB DDR3
  • 750 GB 5400 rpm Hard Drive
  • 15.6-Inch Screen, Mobile Intel® HD 4000 graphics with shared graphics memory
  • Windows 8
  • Running any game but if i try to turn on MSAA to 2x or 4x i get the message MY cOMPUTER RAN INTO A PROBLEM and restart...
従業員
10,036件の閲覧回数
This response has been edited due to its content.
従業員
10,036件の閲覧回数
Hi.
I have similar/same problem.
My PC configuration:
Intel Core i5-3570K
Asus P8Z68-V LX (BIOS Version 4003)
Kingston HyperX KHX1600C9D3/4GX (8GB @ 1600 MHz)
Realtek ALC887 @ Intel Cougar Point PCH - High Definition Audio Controller [B-3] (driver R2.70)
Windows 7 Ultimate 64bit (with latest updates)
I tested this issue on:
Test Drive Unlimited 2
Colin McRae Rally 04
Trine
Worms Reloaded
Hitman Absolution (with v1.0.444.0.Update)
With default Intel HD 4000 Windows 7 drivers (8.15.10.2598) every game works in fullscreen mode (except Hitman - game background is flashing and whole game is dark).
Every later Intel HD 4000 driver (i try: 9.17.10.2849, 9.17.10.2875) above games works good in normal mode (no fullscreen), but when i try switch it to fullscreen (alt+enter) my PC is freeze.
NICHOLAS_F_Intel
従業員
10,036件の閲覧回数
Hi Rooff_,
Can I get you to test out two more drivers and see if you're issue is resolved? The first one is from Asus* for your specific motherboard; http://support.asus.com/download.aspx?SLanguage=en&p=1&m=P8Z68-V+LX&hashedid=QbKg5KhI5BjopWec http://support.asus.com/download.aspx?SLanguage=en&p=1&m=P8Z68-V+LX&hashedid=QbKg5KhI5BjopWec
The second one is our latest driver; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22375&lang=eng Download Center
Give those a try and let me know if it fixes the issue or not.
-Nic
従業員
10,036件の閲覧回数
Yesterday I've downloaded these drivers (downloaded from many sources because I could not found posibilities to download it from Intel website):
8.15.10.2622
8.15.10.2626
8.15.10.2639
8.15.10.2653
8.15.10.2696
8.15.10.2712
8.15.10.2752
8.15.10.2761
8.15.10.2778
9.17.10.2828
9.17.10.2843
9.17.10.2849
9.17.10.2857
9.17.10.2867
9.17.10.2875
9.17.10.2897
9.17.10.2932
I check everyone and:
- drivers 8.15.10.xxxx works as I wrote in previous post
- drivers 9.17.10.xxxx freezing my PC 😕
As You ask I check also latest drivers (9.17.10.2828) from Asus website - still nothing.
The latest drivers from Intel website I've checked yesterday.
I could try to get You more help or clue with some debuger or something.
But You must tell me what i should install or simply what to do
NICHOLAS_F_Intel
従業員
10,036件の閲覧回数
Thanks for that info Rooff, can you post your dxdiag for me to take a look at as well? (Start -> Run -> dxdiag -> Save All Information) Just copy & paste it here and I'll take a look.
-Nic
従業員
10,036件の閲覧回数
thanks Rooff_, finally I can launch all my games normal in fullscreen without having problems. And I really don't understand why or am I that stupid that there are no older drivers on the intel page up? It took one hour for me to get an old Intel driver (8.15.10.2761) and I don't found it on some intel pages or driver storage pages. No I must took it from DELL and thats for a company who is big like intel a joke that there are no older drivers easy to access via service center/downloadcenter.
従業員
10,036件の閲覧回数
System Information
Time of this report: 1/9/2013, 14:12:36
Machine name: HOME
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: Polish (Regional Setting: Polish)
BIOS: BIOS Date: 08/22/12 12:09:15 Ver: 40.03
Processor: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (4 CPUs), ~3.4GHz
Memory: 8192MB RAM
Available OS Memory: 7900MB RAM
Page File: 1901MB used, 6011MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0162&SUBSYS_844D1043&REV_09
Display Memory: 1760 MB
Dedicated Memory: 256 MB
Shared Memory: 1504 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Name: Dell 2209WA(Digital)
Monitor Model: DELL 2209WA
Monitor Id: DELF011
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: DVI
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2828 (English)
Driver Version: 9.17.10.2828
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/3/2012 09:34:54, 8286720 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4222-11CF-FF78-47A4B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0162
SubSys ID: 0x844D1043
Revision ID: 0x0009
Driver Strong Name: oem16.inf:Intel.Mfg.NTamd64:iIVBD0:9.17.10.2828:pci\ven_8086&dev_0162
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC...
従業員
10,036件の閲覧回数
Having the same problem on my MBA. Games freeze and load extremely slowly. I really wish this could be sorted out...
NICHOLAS_F_Intel
従業員
10,036件の閲覧回数
Hi Alec. You'll need to contact your OEM for assistance with this issue (specifically Apple*).
-Nic
従業員
10,036件の閲覧回数
Hello guys. I got the same problem, here is my system:
Intel i5 3570k
Asrock Z77 pro 3 (latest bios 1.9)
16GB Corsair Vengeance 1600Mhz DDR3 Ram
1TB WD HDD
LG Optical Drive
The Onboard-GPU-Chip causes the problem for sure, because with an old Nvidia 8600GT no freezes occured. The temperatures are normal while playing. Windowed Mode didn't fix the problem either.
NICHOLAS_F_Intel
従業員
10,036件の閲覧回数
Hi tomok2404,
Can you provide a copy of your dxdiag please? (Start -> Run -> dxdiag -> Save All Information). Just copy & paste it here so I can take a look.
-Nic
従業員
10,036件の閲覧回数
Sorry, but I wonder... How many dxdiag logs You'll need to look to solve this issue?
NICHOLAS_F_Intel
従業員
10,034件の閲覧回数
Everyones issue is respective to their specific hardware. So I guess I need one per user experiencing the issue
-Nic
従業員
10,034件の閲覧回数
System Information
Time of this report: 1/18/2013, 22:27:52
Machine name: TIM-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: German (Regional Setting: German)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 12/04/12 17:45:24 Ver: 04.06.05
Memory: 16384MB RAM
Available OS Memory: 15310MB RAM
Page File: 3129MB used, 27490MB available
User DPI Setting: 96 DPI (100 percent)
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0162&SUBSYS_01621849&REV_09
Dedicated Memory: 1024 MB
Shared Memory: 736 MB
Current Mode: 1808 x 1014 (32 bit) (60Hz)
Monitor Name: PnP-Monitor (Standard)
Monitor Model: 22W_LCD_TV
Monitor Id: OEM3700
Native Mode: 1920 x 1080(i) (60.053Hz)
Output Type: HDMI
Driver File Version: 9.17.0010.2932 (English)
Driver Version: 9.17.10.2932
DDI Version: 11
Driver Date/Size: 12/12/2012 16:42:36, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4222-11CF-8D70-6821B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0162
SubSys ID: 0x01621849
Revision ID: 0x0009
Driver Strong Name: oem19.inf:Intel.Mfg.NTamd64:iIVBD0:9.17.10.2932:pci\ven_8086&dev_0162
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY Video...
NICHOLAS_F_Intel
従業員
10,034件の閲覧回数
Thanks for the info tomok. Since you've tried using our latest driver, and have fully updated BIOS - I would suggest giving your OEM driver a try; http://www.asrock.com/mb/Intel/Z77%20Pro3/?cat=Download&os=Win764 http://www.asrock.com/mb/Intel/Z77%20Pro3/?cat=Download&os=Win764
Let me know how it goes.
-Nic
従業員
10,034件の閲覧回数
I installed these drivers and my game still freezes:
-Realtek HD audio driver
-INF driver
-Intel Management Engine
-Realtek Lan driver
-Rapid Storage
-Intel USB 3.0
I left out the other drivers, because i think they don't affect the result.
返信
