22690 Discussões
Intel HD 4000 freezes my computer
Funcionário
44.404 Visualizações
I have Windows 8 and Intel HD 4000 graphics. The driver version is 9.17.10.2867. When I try to play a game in full screen it freezes my whole computer. Does anyone else have this problem? And is there a way to fix it?
118 Respostas
Funcionário
5.474 Visualizações
If You look posts in this topic, You find many hardware configuration (generaly MoBo, BIOS, drivers) and the same problem - freezing games in fullscreen with Intel (or OEM) drivers in version 9.17.10.xxxx and Intel HD 4000 graphic.
In my opinion problem is in Intel drivers or their cooperation with DirectX or OpenGL files. It must be some improvement or new feature give in drivers 9.17.10.xxxx...
Funcionário
5.474 Visualizações
I experimented with some Skyrim Settings and apparently the game does not freeze when i am playing in 4:3 and window mode. Can somebody explain that?
Edit: During my first session Skyrim didn't freeze for 5 hours, but now i restarted the game and it froze again, same settings.
Nachricht wurde geändert durch: Tim S.
NICHOLAS_F_Intel
Funcionário
5.474 Visualizações
Hi tomok. I see in that list that you didn't mention whether you tried the VGA driver provided by your OEM yet. It's on that same page; http://www.asrock.com/mb/Intel/Z77%20Pro3/?cat=Download&os=Win764 http://www.asrock.com/mb/Intel/Z77%20Pro3/?cat=Download&os=Win764
Can you give that a try and let me know?
-Nic
Funcionário
5.474 Visualizações
Okay, i will try to download it again. I tried to, but there was alwas a connection problem with this driver. I'll update you.
Funcionário
5.474 Visualizações
i have same problem
i cant play any game when i open game pc instantly freeze
System Information
Time of this report: 1/24/2013, 23:37:07
Machine name: ERTU-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: Turkish (Regional Setting: Turkish)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 12/06/12 16:39:20 Ver: 04.06.05
Processor: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (4 CPUs), ~3.4GHz
Memory: 8192MB RAM
Available OS Memory: 7888MB RAM
Page File: 3694MB used, 12079MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0162&SUBSYS_01621849&REV_09
Display Memory: 1760 MB
Dedicated Memory: 256 MB
Shared Memory: 1504 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: HP x2301 Micro Thin Monitor
Monitor Model: HP x2301
Monitor Id: HWP2972
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2875 (English)
Driver Version: 9.17.10.2875
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 10/23/2012 02:40:20, 12615168 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4222-11CF-C270-6821B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0162
SubSys ID: 0x01621849
Revision ID: 0x0009
Driver Strong Name: oem41.inf:Intel.Mfg.NTamd64:iIVBD0:9.17.10.2875:pci\ven_8086&dev_0162
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY ...
Funcionário
5.474 Visualizações
Funcionário
5.474 Visualizações
i have same problem
System Information
Memory: 8192MB RAM
DxDiag Notes
Display Devices
DAC type: Internal
Monitor Id: HWP2972
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x8086
Device ID: 0x0162
Revision ID: 0x0009
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd...
NICHOLAS_F_Intel
Funcionário
5.474 Visualizações
Hi Ertugrul! Thank you for providing that information and the video. I have some questions for you real quick;
1. What is the make/model your system? If it's a built machine can you provide the make/model of your motherboard please?
2. Can you try and install our latest driver for your system and let me know if it resolves your issue? Here's the link; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22375&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22375&lang=eng
Let me know how it goes.
-Nic
Funcionário
5.474 Visualizações
Hello
i tried install latest driver but it did not fix
But
Good news, Finally i fixed this problem at the moment
Solution Re-Flash BIOS. my last BIOS version was v.1.60 and i re-installed on it ,
and No more Freeze
Hope it helps everybody who have same issue
Funcionário
5.474 Visualizações
I have same problem
MB - ASRock H77 Pro4/MVP
System Information
Time of this report: 2/8/2013, 23:17:44
Machine name: IVI-BRIDGE-3770
Operating System: Windows 7 Максимальная 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
Language: Russian (Regional Setting: Russian)
BIOS: BIOS Date: 12/06/12 17:05:04 Ver: 04.06.05
Processor: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 16384MB RAM
Available OS Memory: 16080MB RAM
Page File: 3073MB used, 29083MB available
DxDiag Notes
Display Devices
DAC type: Internal
Monitor Name: Универсальный монитор PnP
Monitor Model: S23B300
Monitor Id: SAM08AF
Output Type: HDMI
Driver File Version: 9.17.0010.2932 (English)
Driver Version: 9.17.10.2932
DDI Version: 11
Driver Date/Size: 12/12/2012 16:42:36, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4222-11CF-8D70-6821B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0162
Revision ID: 0x0009
Driver Strong Name: oem5.inf:Intel.Mfg.NTamd64:iIVBD0:9.17.10.2932:pci\ven_8086&dev_0162
Funcionário
5.474 Visualizações
Re install your lastest bios
Funcionário
5.474 Visualizações
I have the last version - 1.50. The problem is not fixed.
Funcionário
5.474 Visualizações
I'm pretty sure, that 1.9 is the latest bios provided by ASrock, but don't count on it. Btw, best solution for this problem is just to buy a graphics card, no matter which one, just dont use the hd graphics 4000. Even an old NVidia Geforce 8600GT worked better for me than intels chip.
Funcionário
5.474 Visualizações
latest bios for my motherboard - 1.50.
Funcionário
5.474 Visualizações
just go Asrock website and download bios then install if you have lastest bios version already does not matter reinstall on it anyway
Funcionário
5.474 Visualizações
Hallo there! I 've been trough this problem. And I might have a solution for you.
My configuration:
Processor: i7 3770
Motherboard: ASUS P8Z77-M
RAM: 4x8GB A-DATA 1600 MHz
Windows 7 64x Ultimate
Latest video driver for Intel HD 4000
Latest BIOS
I had the same problem. My system did freeze every 5 minutes. I tried to change all parts in my system. I've tried with different RAM, with i3 processor with Intel HD 3000, with another OS. I even tried to change the power supply. At last I thought that there is some sort of incompatibility with the motherboard. I took a Gigabyte z77 and everything worked perfect. But the ASUS motherboard was fine too. It was tested and there was no problem in it. And the actual problem was a default setting in BIOS. The processor and RAM were not synchronized. They were set to work at ratio 100:133. And every time the processor went in turbo boost mod the result was this "freezing". Now the ratio is set by 100:100 and everything works fine 24/7.
This ratio is called "CPU Bus speed : DRAM speed ratio mode" it is under the tab called Ai Tweaker. In my case there warethree oprions to chose Auto, 100:133 and 100:100. It was set to 100:133 by default. This means when the CPU uses 100% of its frequency the RAM should use 133% of its frequency. This is possible when the RAM is with higher frequency then mine. And in my case I should set this ratio at 100:100. So when the CPU reaches its max speed the RAM will reach its max too. My RAM works now at lower frequence and it works at 1600 MHz when the CPU goes in Turbo Boost mode. The problem was that my RAM can not work at higher frequency then 1600 MHz and it caused errors when it was forced to overclock its speed with 33%.
I hope my experience could be helpful to somebody.
P.S. Sorry for my English.
Funcionário
5.519 Visualizações
@Radoslav Vasilev Do you have any idea what this might be on an ASRock motherboard? The BIOSes of ASRock and Asus are very similar, but ASRock seems to be missing this particular option.
Funcionário
5.519 Visualizações
This option should be in tab called OC Tweaker in ASRock's BIOS. I haven't seen ASRock's BIOS and its options. But there should be option to cahnge the ratio between CPU, RAM, GPU. Yesterday I had a talk with ASRock's owner. He had the same problem but his solution was not the same. He told me, he had to change the parameter "iGPU Violtage Offset" in Tab "OC Tweaker". May be you should take a look what are the settings in your BIOS. If you have some auto tweak options you can try to use them.
Greetings!
Funcionário
5.519 Visualizações
Good time, it helped me:
OC Tweaker - iGPU Voltage Offset = (+100 mV)
Problem solved, but I do not know what is responsible for this parameter. All other settings except the memory timings - by default. I do not know how long it will work. 2 days until there is no problem. (3D Mark 2006, he worked 8 hours without freezing. Now playing Fallaut3 (1920x1080 medium quality).
[P.S.] I speak English very bad.
Funcionário
5.519 Visualizações
PC freezes again yesterday while playing Fallout 3. After I did a test 3D Mark 2006 - 25 cycles - all right. How can this be? I will continue to look for the problem. Tell whether the new releases drivers for HD4000? or not to hope for it?
Funcionário
5.519 Visualizações
18-02-2013 put the settings on here are:
manually in North brodge -> iGPU share memory = auto replaced by 1024 (max).
The third day I test in OCCT - as seen hanging in his tests, while tests 3dmark 2006 to go. Today is Day 3 of "night tests" are the results (I do not know whether all the graphs normally, confuse Vin 4, but by itself taking tests without errors and freezes)
3VCC
AVCC
Cpu Usage
Cpu Vcore
CpuTin
Fps
Memory used
VIN1
VIN4
VIN5
VIN6
Core # 0,1,2,3
Responder
