- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi everyone! Currently at a lost as to how I should go about doing this. I'm aiming to have a dual monitor setup with my laptop connected to both an external monitor and TV.
I have tried using a USB port with both VGA and HDMI, but later read somewhere in this forum that using a USB will not work. I have also tried using a HDMI splitter but then again, it's a splitter and only works one at a time.
My laptop is a rather old one, so I have USB ports, 1 HDMI port and 1 USB-C port. Should I then try a USB-C hub?
Thanks so much in advance!
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
gagadelreyy, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the laptop?
What is the specific model of the monitor and TV?
Was it working fine before with both of those displays connected to it?
When did the issue start?
Did you make any recent hardware/software changes?
Which Windows* version are you using?
Please attach the SSU report so we can verify further details about the components in your platform, please check all the options in the report including the one that says "3rd party software logs":
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Albert! Here are the answers to your questions -
Laptop model: Dell Latitude E7450
Monitor model: Lenovo ThinkVision T2054pC
TV model: Sharp Aquos 32-inch HD Ready TV 2T-C32BG1X
I have yet to successfully connect both displays simultaneously, but both the TV and monitor work perfectly fine when connected individually to my laptop
Not really an issue since I've never tried connecting both monitors at the same time before, and now that I've recently purchased a new monitor I am not sure how to go about doing so and haven't been successful at it...
Nope!
Windows 10
Home
Please attach the SSU report...
Apologies... I'm unable to do so as this is my work laptop that requires administrative access which I do not have. Let me know if there are other ways I can provide this information, perhaps a system information screenshot?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi gagadelreyy, No problem at all, thank you very much for providing that information.
While both monitors attached to the computer, if you open the Intel® Graphics Control Panel / Intel® Graphics Command Center or the Windows* display settings, do you see both monitors being recognized in there?
Do you know the model of the Intel® Processor in the laptop?
Just to let you know, we always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform.
I looked on Dell's website and the graphics driver version they have available is version 20.19.15.5126, A11, please try a clean installation of that driver following the instructions in the links below and then test the monitors:
If the problem persists, then we can try a clean installation this time of Intel® generic graphics driver version 15.40.48.5171:
https://downloadcenter.intel.com/download/30196/Intel-Graphics-Driver-for-Windows-15-40-
We also recommend to get in contact directly with Dell to make sure the latest BIOS version is currently installed or to gather the instructions on how to install it:
https://www.dell.com/support/home/en-us
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello gagadelreyy, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello gagadelreyy, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
