22655 토론
Iris Xe connecting to Samsung LCD LED TV over HDMI -> no HDR
Mage0
초보자
3,803 조회수
I have a 2017 Samsung LCD TV here (UN50MU6300).  It has a menu option for enabling HDR ("UHD color") on specific HDMI ports.  When using this HDR option, I get a strange result connecting my Dell 7306 2n1 to the television.  The TV doesn't detect any signal.  Meanwhile, the laptop's internal monitor goes blank (like I want it to when connecting to an external display), but the laptop seems to flash a brief image of the desktop every 2-3 seconds like it's trying to reconnect or right itself somehow.
Everything works fine at 60Hz sending a 2160p signal to the TV if I stick with SDR in the TV's settings.  Any ideas?
I have tried several combinations of Dell/Intel driver packages for the video chip as well as firmware updates, etc.  No dice so far.                  Thanks - BGU
레이블 (1)
  • HDR
0 포인트
4 응답
David_G_Intel
중재자
3,779 조회수
Hello Mage0
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • Does this happen with HDR only? Is it right after you enable the HDR option?
  • Does this happen if you enable HDR from Windows?
  • Did it work properly before?
  • Can you list some of the drivers tested?
  • Intel® Graphics Command Center report
    • Open the application
    • "Support" > "System Diagnostic" > "Generate Report
David G
0 포인트
David_G_Intel
중재자
3,761 조회수
David G.
0 포인트
David_G_Intel
중재자
3,727 조회수
David G.
0 포인트
Michael2023
초급자
3,043 조회수
I have this exact problem. When Enabling HDR on my Samsung MU7000 (via TV Menu) my HP 15s-FQ2000 with IrisXe screen goes black and keeps trying to enable the external Samsung TV. Laptop display keeps flashing on and off. However if I disable HDR on the TV it works fine. outputting a 4k signal to the TV. If I enable HDR via the TV menu the TV screen goes black and the Laptop screen keeps switching on an off as if it's trying to enable the TV but failing misarably.
0 포인트
응답
