공지
22754 토론
Main display not detect after Update to 31.0.101.5186
Ashkan_2000
초급자
12,035 조회수
After I  update my Intel Graphics Driver 31.0.101.4146 to 31.0.101.5379 and restart laptop My windows start screen keep in black,I connect my laptop via HDMI to an external monitor and see everything work good and my internal main laptop monitor not detect.
I change windows to win 10 and win 11 and test both of them and see on Intel Intel® Graphics Driver 31.0.101.4146 every thing is good, but when use from new driver 31.0.101.5186, internal display shown in black and need to connect another external display (my own is HP 25r) to have screen.
in addition I install driver without Intel Arc control and Issue not solved again.
I attach laptop specs.
pls Guide me if any solution do you have.
0 포인트
11 응답
Mike_Intel
중재자
11,979 조회수
Hello Ashkan_2000,
I checked the SSU and the screenshots that you provided. Let me check if your main graphics is RTX 4050?
Can you check which graphics is enabled in your BIOS?
Michael L.
0 포인트
balcerek
초급자
11,912 조회수
Hello everyone,
I have similar issue. My screen is black after win10 install new Intel drivers: 31.0.101.5186.
When I start Windows in safe mode I see many problems with drivers in device manager.
My computer:
- i11600k without additional GFX,
- MSI z490 Tomahawk motherboard.
Please help me because I can't switch off auto drivers instalation in Win10 so I often can't start my computer.
0 포인트
Ashkan_2000
초급자
6,108 조회수
Hi
I checked and intel integrated graphic is main display driver
0 포인트
Mike_Intel
중재자
11,846 조회수
Hello Ashkan_2000,
Hello balcerek,
Please post a question so that we can appropriately support you as well, as there will be differences between your device.
Michael L.
0 포인트
beepboop123
초급자
11,813 조회수
Intel Core i5 13500 with Intel UHD 770 graphics
Windows 11 23H2 Build 22635.3130
Intel Corporation - Display - 31.0.101.5186 installed approx 3 weeks ago
Since then I've had occasional black screen after login. No mouse cursor, ctrl+alt+del does not work.
0 포인트
balcerek
초급자
11,765 조회수
Hello Mike_Intel,
I have no question for you. I have reported a bug and I'm waiting for fixing the drivers by Intel. Many notifications on forums shows that something is wrong since this version of drivers.
I think that you should ask me for additional infromation eg. about my hardware, circumstances etc.
Many computers (including my) can't work. It is serious situation. You should fix it ASAP.
BTW, the newest drivers (31.0.101.5382) still doesn't work.
beepboop123, Ashkan_2000
I have advice for others users. I found temporary solution. I restored my Windows to previouse state (date) when computer worked.
It has old driver (31.0.101.4889) now but works good.
Then I turned the auto drivers updates off in Windows. It helps for now.
I hope Intel fix this bugs soon and we will use the new versions of drivers.
Greetings !
0 포인트
Mike_Intel
중재자
11,741 조회수
Hello Ashkan_2000,
Thank you for the feedback.
We will investigate this one further and we will keep you posted on this thread as soon as I have an update.
Michael L.
0 포인트
rubengarc2801
초급자
11,584 조회수
Hi there
I wanted to roll into this topic as we have the exact same situation. I am working as an IT service provider in zurich, switzerland and one of our customers has the same issue.
After 31.0.101.5186 installed via Windows Update, this broke our second monitor function for around 10-12 clients. We are using mostly HP Elitedesk Mini 600 G9 with IGP UHD 770 in our setups and they are all connected via DP to Monitors Philips PHL241B8Q and Windows shows the monitors up as it should (this makes remote help very complicated).
We have other PC Setups with the same Clients, but HP Monitors (mostly E24i) as well - all of them are working just fine with the HP DP Cables. We are not considering a cabling problem as this problem appeared on a lot of computers after the same update.
After rolling back drivers to our working condition before (31.0.101.4502) the Philips Monitors still refuse to work - even after shutting them off and on again or unplugging the DP cable and plugging that in again.
My next try was upgrading the HP OEM driver to the latest stable version from Intel Support (31.0.101.5382) but there is also no working second display after replugging the powercord unfortunately.
It seems that version 31.0.101.5186 breaks something. We did not reinstall any computer yet.
Can you help us with this or escalate? I am on-site this early afternoon and will have a complete detailed protocol about the computers with the issue.
We can provide you more details if you need them, just hit me up and i can work with you, in case this helps getting a solution.
And i guess we are not the only one with that situation - thats why we made the account extra for this here.
Looking forward to your response, have a nice day so far!
Greetings, Ruben
0 포인트
Mike_Intel
중재자
11,564 조회수
Hello Ashkan_2000,
Upon further review, you are operating on an Vivobook_ASUSLaptop K6602VU_K6602VU computer. We would like explain that while we do supply a generic graphics driver, it is generally recommended to utilize the custom graphics driver provided by the OEM or system manufacturer, as it is likely to be more compatible with your system.
You may also check this link for the troubleshooting guide.
How to Resolve Issue with Black Screen While Using the System with Integrated Graphics
@rubengarc2801
Michael L.
0 포인트
beepboop123
초급자
10,993 조회수
Still having issues on 31.0.101.5382. I see there's 31.0.101.5444 available at https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
In the release notes against "Intel® Arc™ Control Fixed Issues:" it mentions: "Intel® Graphics Driver Installer may experience intermittent hang with black screen."
Fingers crossed.
0 포인트
beepboop123
초급자
10,311 조회수
Having run 32.0.101.5444 without any black screen issues, I got my first today in a while. I checked the version and it's 32.0.101.5510 which is not listed at https://www.intel.com/content/www/us/en/download/785597/821201/intel-arc-iris-xe-graphics-windows.html - this came via a Windows Update on 9th May. I'm on the "beta" Insider ring for Windows Insiders.
Going to manually install the latest 31.0.101.5518 from here.
Related? https://community.intel.com/t5/Graphics/intel-32-0-101-5510-display-glitches/m-p/1597536
0 포인트
응답
