Hi! I'm sending you this message because I'm having an issue that's ruining my gaming experience. Indeed, when I play Minecraft some blocks no longer have textures and turn black or green.
I play on the modded version of Minecraft (Forge).
I have no choice but to be on this version to play on the server.
The problem is with my Intel(R) UHD Graphics GPU.
I was then advised to download an older version of the Windows DCH drivers (https://www.intel.fr/content/www/fr/fr/download/19344/685037/intel-graphics-windows-dch-drivers. html)
However it is impossible for me to download this version on my laptop. When I run the .exe, I get an exit code: 8. Because I guess the driver may not be compatible with my laptop.
I am still looking for a solution to my problem,
Best regards !
I noticed the same problem on the forum: https://community.intel.com/t5/Graphics/Minecraft-showing-as-one-solid-color/m-p/1450228
Hello LeMiniCocoX
Thank you for posting on the Intel Communities. I am sorry you are experiencing graphics corruption issues when playing Minecraft on your system with Intel® UHD Graphics.
We only support the latest version of the game, please let us know the version that you are using and in case it is not the latest one, verify and check if the issue happens on the latest version. If the game has mods installed, check if the issue happens without mods.
The driver that you mentioned in your post is indeed not compatible with your hardware. I would advise installing the latest driver provided by your system manufacturer version 31.0.101.4255.
Hugo O.
Hello LeMiniCocoX
I hope you are doing fine.
Let us know if you have further questions.
Hugo O.
Hello LeMiniCocoX
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
Hello Hugo
I play in version 1.6.4 Forge of Minecraft. This version is required to play a server (NationsGlory). When I play on the latest version of Minecraft (without mods), I have no problems! The server advised me to download this version because it is supposed to fix all texture problems. https://www.intel.fr/content/www/fr/fr/download/19344/685037/intel-graphics-windows-dch-drivers html
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
