Hi all,
I have a "Intel® NUC Kit NUC8i7HNK Elements", it connected with HDMI cable to my TV
Philips 46PLF9704.
Now my problem:
The screen turn pink / blue, after a time its goes back normale.
I did update all my drivers.
But by making a screenshot i fond out it's the TV, the screenshot are the collors normal.
What settings can i change to solve this problem?
I realy like the NUC, hopes to find a sollution.
Switch OFF:
- Virtual super resolution
- GPU Scaling
Set:
Pixel Format to RGB 4:4:4 ... (Full RGB)
Color Depth to 8 bpc
Leon
To me, this looks like the result of a bad HDMI cable or cable connector. I suggest you try a better quality cable.
Hope this helps,
Maybe in the Radion setting, 'but dont know what it is.
All monitor connection points on the HN/HV NUCs are directly connected to the Radeon RX Vega M graphics engine. You definitely need to be looking at the Radeon software for any configuration changes.
Do you know what i must change?
Switch OFF:
- GPU Scaling
Set:
Leon
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
