- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
i am having strange problem...
I bought 2 monitors from Lenovo and when pluged both in one is not detected...
I tested...
- plug in one monitor in front and rear hdmi input - it worked
- plug in other monitor in front and in rear hdmi input - it worked
- plug in both - one is working second one not
- right click on dwsktop - screen options - multiple screens - DETECT - no detection
- in device maneger there is just "generic pnp monitor" but just one
- in intel control panel for graphics - display - connected displays - all time refreshing no information about screens
- all drivers up to date from 6.1.2021
- all drivers from intel driver support assistant are updated
Is it possible that nuc8i7 supoorts only one HDMI display? Other need to be on display port? I had once problem on big tower PC.. graphic had DVI and 2 display port outopts... but it worked for 2 displays only... so 3 outputs but only 2 connected... so otions were 2... one DVI and 1 port OR port and port.... its 15yers old PC 🙂
I am waiting for display adapter from mini displayport to hdmi so i will try that option...
Got any ideas?
So i am trying to activete both HDMI outputs in same time...
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
First of all, please don't refer to any NUC using a term like NUC8i7. There are a whole slew of NUCs whose model name begins with NUC8i7. First, for kit products, you will see NUC8i7INH, NUC8i7BEH, NUC8i7BEK, NUC8i7HNK and NUC8i7HVK. Then, for system products, you will see NUC8i7INHGA, NUC8i7BEHGA, NUC8i7BEKQA, NUC8i7HNKQC and NUC8i7HVKVA.
Yes, I am being a bit **bleep** here, but you must see the issue. If you really must short-form the name, you should start by specifying the family code - IN, BE, HN or HV (all of which imply the NUC8 portion). In the case of HN and HV, the family code is usually sufficient for any discussion that does not require the specification of the system's memory and/or storage context. For IN and BE, if it really matters to the discussion (which is also fairly rare), specify the H or K for the chassis type and the i3, i5 or i7 for the processor type. For more information, consult this page: Intel NUC Identification.
So, with that out of the way, let's discuss you issue...
For the HN and HV NUCs, the Intel HD Graphics engine in the processor is not connected to nor has any control over the graphics outputs; these are all owned and controlled by the AMD HD Graphics engine. What this means is that the Intel Graphics Control Panel and Intel Graphics Control Center applications should not be used. Instead, you should be using the AMD Radeon Software application.
Finally, no, the two HDMI ports, the two DisplayPort ports and the two USB-C/TBT3 ports are all independent and can be used in any combination. Using the two HDMI ports is perfectly fine.
Hope this helps,
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
So the device specifications say i have
Processor: Intel HD Graphics 630
Discrete: Radeon RX Vega M GL graphic
Can you help me the right software? Or control center?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I went to safe mode by this command
bcdedit /set {default} safeboot network
And remove drivers and start optimistic reinstalling all...
No resoult... still freezing NUC
Maybe you can provode me a software with latest drivers... this freezing problem was solved with drivers from 5.1.2021
But when i reinstall new drivers computer works but not with both screens
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Working drivers:
Gfx_win10_27.20.100.8681
But just to be shure...
Now in device manager by graphic tab is this:
Intel HD graphics 630
Driver from 5.9.2020
Microsoft Basic Display Adapter
Driver from 21.6.2006
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
You can be running any version of the Intel HD Graphics driver, but the AMD Radeon HD Graphics driver needs to be the 20. 2.2 release that Intel supports (there are ways to upgrade to newer versions, but let's stick with this "supported" version for now). You can download this version from here: https://www.amd.com/en/support/kb/release-notes/rn-rad-win-20-2-2.
Now, as for the AMD Radeon Software app, unless you specifically deselect it, it is going to be installed with any version of the driver package. It is accessed by right-clicking on the display and selecting the entry for it in (at the top of) the context menu.
I have two monitors connected to the two HDMI ports on my HV, one 4K TV and one 3K monitor (no, that's not a typo, it really is a 3K monitor), and I see them both working without issue. Just to be sure, I connected these monitors to a second unit and they continue to be supported just fine.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I remove both graphic devices in device manager with drivers and restart pc
I install igfx_win10_100.9168
Than i install the AMD Adrenaline package v20.2.2
But in my case... if i dowbload mini pack for auto detection it gives me error code 182 that means no supported device
And allso try to just instal 20.2.2 package... it start the installing process but frst time that screen blinks it stay black
After hard reset it comes to windows for 15s and freezes
If i go to device manager and manualy update drivers without Adrenaline software install it start to update drivers and same stori... first blink it stay black screen... after hard reset it freezes in 15s
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Allso try to install Adrenaline 20.2.2 and i got black screen... after hard reset it freezes....
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Is there any other support from INTEL? Like service fabric team or something?
This is problem from begining... if i send the device to service again my company will stop for 30days becouse this pc have basic program that run my company...
Can i contact fabric or anyone else? I really dont have any new idea...
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
@Ronny_G_Intel/@Chris_V_Intel, please have someone assigned to this issue.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks for your responses and answers to my problems for thin NUC8i7HNK and for all advices that you shared with me.
Big thanks
I will let you know if all is o.k. with new second ram unit
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Did you test the DRAM when you put the system together? One should always test memory accesses from a new system or a system whose DRAM is replaced. I always run MemTest86 (or MemTest86+, but that's off the table for now (forever?) now that (unsecure) Legacy Boot support is being depreciated) for a full 24 hours when I put a new system together. I consider this part of my burn-in of the system.
Just saying,
