22662 Discussões
Valorant Driver Compatibility Issues - UHD 620
JensA
Novato
196.955 Visualizações
Ever since upgrading the UHD 620 (i5 8250) drivers on my laptop, I've been having game-breaking stuttering whenever a 3d entity loads (which is almost constantly) in Valorant.
More details in the "Graphics bug report" form attached.
Etiquetas (1)
130 Respostas
RonaldM_Intel
Moderador
22.668 Visualizações
Hello everyone,
No news from Intel's side yet. After multiple tests (on several different platforms) our debug team has been unable to reproduce the lag issue.
Just to reiterate, on different processors of different generations (6th gen and up to 11th gen) running on mechanical drives and SSDs (including m.2) and yet the lag issue is not occurring. So far this would indicate the issue is triggered by something different than the graphics driver, and yet "impacted" by it.
Has any of you tried with the combination of clean OS installation and driver 27.20.100.8935? (this should suggest no OS update or 3rd party app has had time to get installed).
Ronald M.
Shanthosh
Principiante
21.766 Visualizações
I think it is because of the HDD too, I installed the latest 20H2 Windows fresh and disabled updates as soon as I connected to the internet, and got the newest drivers from the Intel site. The game still stutters to hell, in task manager the hard disk usage spikes to 100% whenever it freezes while my CPU, GPU and ram are below 50%. I have an i3-7100u, Intel hd 620 with 12gb Rams (dual channel 8+4)
i5_1035G1_Sat24
22.532 Visualizações
Is the latest driver  27.20.100.9077 shown some improvements ? Pls anyone update after trying.
NORMAL
Novato
22.505 Visualizações
No, they did not fix it. I tried the latest version but no luck. I think they don't even care about this .
henriquesmarques
Principiante
22.481 Visualizações
Version 9077 did not work for me, I still use version 8190 which is the only one that behaves well for me.
MarkApud
Principiante
22.396 Visualizações
Hi everyone! I've been dealing with the same issue for months now, i've first noticed it on september, but never found any solution from the valorant support team here in LATAM. They just told me to uninstall all drivers and let windows do the rest.
So I deleted all drivers and played with an old version that windows installed automatically, getting fewer lag spikes, but it's still wasn't the same as in the game's beta when i could play it without any trouble.
But today i reinstaled (silly me) the new version (Dec 23 - 27.20.100.9079) and got those old lag spikes that i thought were gone/fixed.
So i came to be alerted when they get to any solution.
I have an i5-7200U with 2x4GB DDR4 and an intel HD 620.
Sorry for my bad english (Argentinian here!).
Hope we get a solution soon!
henriquesmarques
Principiante
21.996 Visualizações
news??
MarkApud
Principiante
22.310 Visualizações
Hey just got your reply and came to share my experience:
I upgraded to ssd 2 days ago and ALL PROBLEMS ARE GONE.
I got the latest update and it plays like a charm. Feels like a totally different pc.
I cannot recommend you to upgrade to ssd any harder. Seriously.
Again: sorry for bad English.
Hope you get any response from the team. Cheers!
JLSQE
Principiante
18.365 Visualizações
buenas compañero latinoamericano queria saber si instalaste el juego en la ssd
Deep2
Principiante
22.170 Visualizações
Hello there,
I was just wondering if a solution to this issue was found as I am facing the same problem currently. I was able to play with no stutter and around 40 fps, which was enough, but on Feb. 13,  it suddenly began to stutter. The only difference is that my laptop uses the Intel Graphics 620 not the UHD version.
i5_1035G1_Sat24
22.160 Visualizações
Is there any progress ? or the upgrade from HDD to SSD is the solution (as said in some replies).
igorxdd76
Principiante
21.888 Visualizações
Same problem here, i make a clean installation of windows, update all the devices and then install valorant, the game spikes every moment, every new actions in the game spikes and then goes to normal in 1~~2 seconds.  i resolve this issue with a rollback and back to 27.20.100.8476 Driver.
srry for bad english 🙂
Intel i5 8400 processor
Intel HD graphics 630
HDD SATA 500GB
shark03
Principiante
21.891 Visualizações
I have the exact same issue as everyone here.
Intel i5-8400T Processor
Intel HD Graphics 630
3rdDeathBringer
Principiante
21.908 Visualizações
I have an intel UHD 620, an i5-8265U and a SSD with 8GB and I don't have such a behavior. My game is running at a constant 55-60FPS (vsync enabled). So yeah must be a hard drive issue
i5_1035G1_Sat24
22.064 Visualizações
Only after a certain update I am (or all of us) are getting this issue, so it is clearly a driver issue which is maybe not affecting SSDs.
Seckond
Novato
21.513 Visualizações
Which version of intel UHD 620 are you using?
Seckond
Novato
21.455 Visualizações
Downloading a older driver version worked for me
sPiel
Principiante
21.769 Visualizações
I apologise in advance if I'm hijaking this thread.
I don't have Valorant but have noticed the same symptoms with the latest driver, playing Path of Exile and Skyrim.  Both were quite playable before the latest driver update from Windows, and both are now completely unplayable.  However, Path of Exile now works with the Vulcan renderer, where it did not before.  Interestingly, Valheim still runs fine (well, as fine as it ran before).
I don't really have time to do gather logs/videos etc. but I thought it might be helpful to know that the driver has bricked other games as well.
I'm running:
HP Dragonfly elitebook
i5-8365U @ 1.6GHz
UHD 620
8GB RAM
SSD
Castaft
Principiante
21.606 Visualizações
Is this issue under investigation?
My system:
i5 8250U
4 + 4 GB 2400MHz CL 17 RAM
1 TB 5400RPM HDD
UHD 620
Radeon 520
When I select the Intel UHD 620 from the graphics settings section before entering the game, the game remains black and uses my Radeon 520 graphics card. When I disable my Radeon 520 card from device manager, when the skin is loaded, my FPS drops to 1 and the game becomes unplayable.
4 months ago I could play the game with 100+ FPS. There is no problem with temperatures.
Driver version: 9316
Seckond
Novato
21.480 Visualizações
Try download a version older than 8476 it works for me
henriquesmarques
Principiante
21.536 Visualizações
I would like a better solution than an older driver (the driver is hardly any more) and the ssd, because at the moment I am not able to buy an ssd.
Sorry for my English, I'm using a translator.
Responder
