22678 討論
Video capture not working on 12700K and UHD770
Sławek
員工
2,803 檢視
During my struggle with The Witcher artifacts (in the another thread) I tried to use video capture capability that is visible in Intel Graphics Center tool, but without success...
I have Windows 11 Evaluation installed.
Does this feature it work with UHD770 ? I tried to use all drivers available and with all of them I have a nice message with advice to update video driver...
Does anybody was able to use video capture feature on UHD770 ?
Sławek
0 積分
4 回應
DeividA_Intel
員工
2,781 檢視
Hello Sławek,
Thank you for posting on the Intel® communities. I understand you are having issues with the Intel® Graphics Command Center (Intel® GCC).
I do appreciate your report, I will check internally this behavior and as soon as I have any details I will let you know.
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Deivid A.
DeividA_Intel
員工
2,764 檢視
Hello Sławek,
In order to continue with the investigation, I would appreciate it if you provide the following:
1. Have you tested Windows 11 non-enterprise version? if so, what was the result?
2. Is there any reason why you are using this Windows version?
3. Can you share a video of the issue?
4. Did you perform the clean installation method to install the drivers?
5. Did you try to reinstall the Intel® Graphics Command Center (Intel® GCC)?
Deivid A.
Sławek
員工
2,754 檢視
Hello Deivid,
I would like to answer your questions but all that topic is now outdated because new official drivers 30.0.101.1340 released fixed my problem 🙂 I performed normal incremental update and Video Capture is now working perfectly.
Thank you and have a good day 🙂
Sławek
DeividA_Intel
員工
2,747 檢視
Hello Sławek,
I am glad to know that the latest driver version fixed the issue. Bear in mind that you can open a new thread in case you experience any other issues with Intel products.
Thanks for your time and comprehension.
Deivid A.
回覆
