22643 Discussões
Where is Intel USB 3.0 Extensible Host Controller driver for Microsoft Windows 8?
Funcionário
194.534 Visualizações
I seached within Intel Support and what I got were Intel USB 3.0 Extensible Host Controller drivers for MICROSOFT WINDOWS 7.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=intel%20usb%203.0%20extensible%20host%20controller http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=intel%20usb%203.0%20extensible%20host%20controller
Microsoft Windows 8 was released yesterday, October 26 and where is the compatible driver for it?
Could an Intel technical support representative feedback to technical support about this problem?
253 Respostas
Funcionário
38.168 Visualizações
I'm trying to figure out which version carminus you've posted and did you see the http://www.station-drivers.com/page/intel%20chipset.htm Station-Drivers where they have version 2.0.100 beta which is the one I want to try using, how do we modify it ourselves?
I tried this but your readme says to use iusb3hub while pluggable's says to use iusb3xhc
So which one is it huh? I tried iusb3hub and my system showed a device that was not recognized but it showed the eXtensible Controller as being installed correctly. WHICH ONE IS WHICH!!
Funcionário
38.170 Visualizações
I have version ending with .420..... What version have you uploaded (looks like 1.0.7.248) ? May be your version can help me....
Funcionário
carminus,
Thank you!
To everyone here the guide to modify these yourselves is https://docs.google.com/viewer?pid=explorer&srcid=0B1iTNRmwaw54RWMyd3hUVV9WZkE&docid=fb24ed30dc61006d2858472c60f66e4c|13b25755bf389d3c3cb64d49f4e862f0&chan=EQAAALQ6iryec1hadS6vCjWyJsDDbCtoeBI/PDSC8/cwcBQz&a=v&rel=zip;z3;Instructions.txt HERE
Also there are beta drivers online at http://www.station-drivers.com/page/intel%20chipset.htm Station-Drivers version 2.0.100 beta however even following ekko's guide nothing worked. I did a search for one of the strings and discovered this warning:
WARNING: BETA version!
Updated for Intel 8 Series/C220 series Chipset Family (2.0.0.100) only for 4th generation Intel® Core™ Processor Family (Haswell).
So we definitely can't use these, it also implies they may not update the drivers for Intel 5/7 series anymore idk what to make of it.
HSche5
Principiante
38.169 Visualizações
The Intel drivers for my Intel dx79sr MB are Renesas drivers and your instructions reference only Intel drivers. Front inf is nusb3hub.inf and rear is rusb3hub.inf.
Would I just substitute?
Funcionário
I have been away from the thread for a while, but I see the comments seem to be about the same.
So wingdam, just in case you have not seen this before, Windows 8 comes with drivers for your USB 3.0 controllers. Since you said you have a Renesas driver, I installed an add-in US Robotics USB 3.0 card to test.
Did a clean Windows 8 install and no downloaded drivers (no internet connection), so all drivers had to come from the Windows 8 Install media. All (including the add-in card) of my USB 3.0 ports are working at 3.0 speeds.
My ASUS Z77 board already had ASMedia and Intel USB 3.0 controllers. I notice the Z79 chipset does not have native Intel USB 3.0, or at least it does not appear to. I did notice the Intel reference on the extensible controller on my board changed to Renesas after I installed the add-in card.
All of the controllers and USB Root Hubs (xHCI) are using the same drivers and .inf file to set them up.
UCX01000.SYS
USBXHCI.SYS
usbxhci.inf
USBHUB3.SYS for Hubs.
The bottom line is I feel complaining to Intel about needing a driver is not the correct way to address the situation. If your USB 3.0 ports are not working in Windows 8, I would think it is for one of the following reasons.
Your install media is corrupted.
Some device in one of the USB 3.0 ports is effecting the drivers.
A problem with the physical connections to the off board ports, which might effect them all.
A problem with the motherboard/USB 3.0 controller.
There is another poster in this thread has the same motherboard as me, and even though my ports work fine, his do not. This fact alone shows me Windows 8 has the necessary drivers, but in some circumstances, they do not work. If you run all the tests you can and cannot get the ports to work with the Windows 8 version, I would suggest returning the Motherboard.
Just in case you were wondering, I receive no incentive from Intel for anything, so I am not here to help them, but I would like to see the issue resolved correctly.
TNich3
Novato
This is frustrating. I successfully installed the modified drivers, but it made no difference on my Hitachi Touro Mobile Pro which works fine on my brother's computer with a Renesas USB 3.0 add-on card. (USB 2.0 devices previously connected to my USB 3.0 ports still function as they did before. This is really the only issue I'm having with Windows 8 because I can't access this hard drive unless I use my brother's computer.
Even if I get the Hitachi drive to connect to my computer's USB 3.0 ports, the drive is still useless as a portable storage device because my laptop's USB 2.0 ports cannot even recognize this drive in its current state. I'm at the point where I'm just going to try to bust the HDD out of the enclosure and install it in a different USB 3.0 enclosure to see if that will work with Windows 8.
Funcionário
I have a Samsung Series 7 http://forum.notebookreview.com/samsung/660337-new-samsung-series-7-np700z7c-s01us-laptop-i7-3615qm-650m-review.html NP700Z7C-S01US Laptop i7 3615QM 650m
I am testing with 3 USB 3.0 devices. 2 External drives and one media reader. I have not put Kies on my machine. All of my USB 3.0 device can connect to the USB interface but they run at USB 2.0 speeds. In the "personalization" menu under devices, one of my devices says "you can run faster with USB 3.0" even though it IS plugged into USB 3.0. The other doesn't warn about the connection speed, but it also still runs at USB 2.0 speeds. An external 3.0 Compact Flash reader (SIIG) can not be read over the USB 3.0 at all, but runs fine on the USB 2.0 side. Also, it runs fine on my Asus G51SW laptop on the USB 3.0 port, and both external USB 3.0 drives run at full speed on the Asus.
Something is wrong the with USB 3.0 driver or the interfaces themselves on the Samsung series 7 (17")...for sure.
I don't believe I have the Renesas controller. The Intel one is the one I have.
Intel(R) USB 3.0 eXtensible Host Controller- 0100 (Microsoft)
No Renesas in the device manager. I simply looked at transfer speed in windows 8...they are around 25-30 Mb/s. USB 2.0 speeds.
In fact, when I plug my drive in, which is a Seagate USB 3.0 drive, in the personalization area under devices, it shows that my "device could perform faster"... yet it is on a 3.0 interface and is a 3.0 drive! This is obviously a Windows 8 and Intel issue.
Sigh.
Funcionário
Hi to all community
On my n56vz win8pro i7 3630qm still not working usb. Actually, it works at usb2.0 speed with stock drivers but with the modded ones i got noyhing working, i've done the right procedure a few times but no fortune
I'm using an external hard drive usb 3.0 that works at 100mbs on every computer but not on my laptop.
thanks in advice for your help
Funcionário
38.344 Visualizações
I feel like this is an issue between the Extensible Intel driver and the motherboard chipset drivers. Mine still only work at usb 2.0 speeds or dont recognize a device correctly at all.
YKara2
Principiante
Intel USB3.0 Driver Ver:1.0.8.251 03/31/2013 http://downloadmirror.intel.com/21129/eng/Intel(R)_USB_3.0_eXtensible_Host_Controller_Driver.zip http://downloadmirror.intel.com/21129/eng/Intel(R)_USB_3.0_eXtensible_Host_Controller_Driver.zip
for Win8 x64 https://docs.google.com/file/d/0B4DP8nUbwgu5VkZGVlNRdGZYak0/edit?usp=sharing Win8 USB3 x64.7z - Google Drive
bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit -set TESTSIGNING ON
reboot
install driver and
bcdedit -set loadoptions ENABLE_INTEGRITY_CHECKS
bcdedit -set TESTSIGNING OFF
reboot
Funcionário
If this works...you are " T H E M A N " Period.
Funcionário
It just comes back with the driver software for your device is up to date.
The driver page you're linking to does show it's been updated on 3-31 but it still doesn't include support for Windows 8.
JSmej
Principiante
reboot
install driver and
reboot
/servlet/JiveServlet/showImage/2-188957-231823/diskbench.png
Ok so is this the way to do it if we want Windows 8 USB 3.0 driver updated?
I'm confused by what Sam DeRenzis wrote. This all seemed legit until Sam posted something that requires a questionable .exe app just to download the driver.
_________________________________________
"Sam DeRenzis wrote:
Thank https://docs.google.com/file/d/0B1iTNRmwaw54RWMyd3hUVV9WZkE/edit?pli=1 Ekko for his original work and here is the newest driver modified by me which runs fine in Windows 8 x64. I didn't do the x32 you can do it if you wanna.
http://speedy.sh/X2YdT/Intel-USB-3.0-eXtensible-Host-Controller-Driver-1.0.8.251-03-31-2013.zip Intel USB 3.0 eXtensible Host Controller (Driver 1.0.8.251) (03-31-2013).zip - Speedy Share - upload jyour files here"
Why would I trust "Tiny DM manager (exe app) " ? Even Chrome suggests I should discard it after I download it The last thing I need is some spam toolbar installed.
You_must_fix_if_inte
Principiante
38.160 Visualizações
Please re-upload new links, not all working
Thank you!
There is problem in windows 10 (all up to 1909) with some external HDD
Driver from Fernando lets disk read but problems with write - disk going unmount randomly when writing
https://www.win-raid.com/t834f25-USB-Drivers-original-and-modded.htmls
Some guy told that he copy windows 7 driver and give private-not working more site with instructions
but direct copy or trying instal by upper insctruction dont help
"I have copied drivers from old Windows and overwrite them into Windows 10. That works
I make it here:
thoaimedia
com/how-to-fix-hitachi-external-usb-3-0-3tb-hdd-touro-desk-pro-unrecognized-in-windows-10/"
(try use google drive and mega trying to save for longer)
GHoli
Principiante
I guess I'm slightly confused......as I see that I now have driver Intel USB 3.0 eXtensible Host Controller:
Driver: Microsoft
Driver Ver: 6.2.9200.1668
Driver Date: 5/31/2013
This was provided by the April 2013 Windows 8 Cumulative update mentioned by Curtis....
My USB Root Hub (xHCI) driver is:
Driver: Microsoft
Driver Date: 5/3/2013
Driver Ver: 6.2.9200.16604
Then I see a link posted above for the Intel USB 3.0 driver:
Driver: Intel
Driver Ver: 1.0.8.251
Driver Date: 3/31/2013
The Microsoft driver seems to be working fine......and it is a later dated driver then the Intel driver....should I just let it go with this latest Microsoft USB 3.0 driver....lol
Funcionário
I recently bought a Lenovo Core i7 Windows 8 laptop. Problem which is driving me nuts now is that I could not sync an MP3 player and I get an "the device is incompatible" message. The driver had a yellow triangle next to it but Windows told me the software is updated. I also received Code 31 and 43 messages and out of desperation uninstall the driver. How do I get the driver back and how do I get my MP3 player to sync and play?
Funcionário
This is still just for Windows 7. It would appear they have only added two fixes in this Windows 7 release.
USB3.0 devices behind a USB3.0 HUB may disappear after system
reboot
Resolved in Release Rev: 1.0.8.251 (PVHF8)
"Allow this device to wake the computer" option for HID-compliant
mouse/keyboard under the Device Manager may be unchecked if
the mouse/keyboard is connected behind the USB3.0 port and the
USB3.0 driver is installed.
This still isn't a solution for Windows 8.
Funcionário
Oh well. I will keep waiting. This is basically the last thing I need to fix on Win 8 for my Samsung Series 7 Chronos laptop.
Funcionário
The issue I'm seeing is with a Warpia SWP120A. The device works fine when I plug it in but if I unplug it and later plug it back in before I reboot it doesn't work. I get an error that says the driver is already in use. This is the same thing that happens if I plug in a second Warpia device.
It acts like the controller doesn't unload the driver when it's unplugged.
Funcionário
http://speedy.sh/X2YdT/Intel-USB-3.0-eXtensible-Host-Controller-Driver-1.0.8.251-03-31-2013.zip Intel USB 3.0 eXtensible Host Controller (Driver 1.0.8.251) (03-31-2013).zip - Speedy Share - upload your files here
Funcionário
Is this legit? Can anyone confirm?
Responder
