- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
After updating to the latest HD 630 graphics driver, In my advanced display setting its showing as 6 Bit depth making whole display as sluggish and dim it usually was in 8 Bit before updating, Please provide a solution for this ASAP.
System is ASUS FX 504 GE with Intel Core i5 8300H with 630 as integrated and Nvidia 1050Ti as dedicated.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Team,
I have tried installing latest version(some version called .6577 updated this month only) and still same problem continues , tried a previous versions(at least went 3 to 4 versions back and installed)but no different results display will be slow and sluggish.
When the system is in Microsoft basic display screen bit depth will be in 8bit.
Also when only Nvidia driver is installed display bit depth will be 8 bit , after you install a Intel driver problem persists.
Please suggest a solution ASAP.
Sam
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I am also getting 6bit on i5 7200u intel HD 620
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for your response.
- latest driver dch_win64_25.20.100.6577 and dch_win64_25.20.100.6444 and even win64_24.20.100.6229
- As of now I don't remember because Intel driver utility used update so haven't tracked those.
- Yup updated to the latest version i.e Nvidia Verson 419.17
- Have attached the required .txt files please go through it.
As we all are facing this issue on a laptop common ground please solve this issue.
Sam
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Team,
Yes, It shows as 6Bit when I connect the laptop to a external display.
and Yes have already raised the ticket regarding this in Asus forum.
Sam
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
HI Team,
Latest driver is not available to download it seems,
Fixing will be back soon this is the status of the latest driver.
so waiting for your team to re-release it.
Sam
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Team,
The issue still persists, have installed the new driver and all.
Installed as you explained in above replies.
Still it showing as 6 Bit depth only.
Try to resolve this issue as I can see this driver didn't solved anyone's issue.
Sam
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
