In all games and I mean it, in all games that I try to play on Intel Core i5 CPU with newest Windows XP drivers (XP SP3 32bit with all updates is installed here) Intel HD Graphics drivers hang/freeze from 2 minutes of playing to 2 hours of playing.
E.g. Far Cry 1 patch v1.4, usually hangs 3-15 minutes through playing. King's Bounty The Legend hangs in just 1-2 minutes after you start playing.
This problem occurs much sooner during the course of playing if I enable only 128MB of system RAM allocated to this GPU, and a bit later if I set DVMT to use maximum allowed system RAM.
My hardware configuration:
CPU: Intel Core i5 660
Motherboard: ASRock H55DE3
RAM: 4GB DDR3
OS: Windows XP SP3 Professional with all updates installed, as well as the latest available downloadable drivers.
I don't have desire, nor money to upgrade to Windows 7.
This problem is also mentioned /message/73781 here, /message/74629# 74629 here, /thread/9537 here, /thread/9171 here, /thread/12928 here, /thread/13040 here and in many other threads too.
It must be a shame to Intel, but in reality it seems like they don't care. Threads are unanswered, people are dissatisfied.
OK, the exact error messages are:
The driver igxprd32 for the display device \Device\Video0 got stuck in an infinite loop. This usually indicates a problem with the device itself or with the device driver programming the hardware incorrectly. Please check with your hardware device vendor for any driver updates.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Application popup: Windows - Display Driver Stopped Responding : The igxprd32 display driver has stopped working normally. Save your work and reboot the system to restore full display functionality. The next time you reboot the machine a dialog will be displayed giving you a chance to upload data about this failure to Microsoft.
Far Cry 1, patch 1.4 error:
King's Bounty The Legend, patch 1.7 error:
King's Bounty The Legend, patch 1.7 settings: http://yfrog.com/9hsbountythelegendv17grapj
I will bump this thread indefinitely until this (these) bug(s) is (are) fixed.
Here's the last Windows minidump when the error occured.
http://www.mediafire.com/?tg2ye3nuaet Download
If you need a full memory dump, I can do that for you.
The exact error message (for Google and these forums search) is:
Like I promised, this is the first bump.
The second bumb because Intel programmers don't give a f*ck.
Call of Duty: Modern Warfare 2 crashes almost instantly as soon as you start playing:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
The problem seems to be caused by the following file: igxprd32
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
The device driver got stuck in an infinite loop. This usually indicates problem with the device itself or with the device driver programming the hardware incorrectly.
Technical information:
*** STOP: 0x000000EA (0x891D3620,0x89B4B340,0xF78CECBC,0x00000001)
igxprd32
I have the same issues.
Name: Intel(R) Graphics Media Accelerator
HD Memory size 256 MB
laptop model:acer 5740
Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz
I got igxprd32 error crash while playing ea sports cricket 07 and INTEL SHOULD SHOULD FIND THE FIX
FOR THIS ISSUES WHILE CONTACTING CUSTOMER CARE IN ACER THEY TOLD IN MOTHERBOARD IN INTEL.SO EVERYBODY WANT THE
FIX FOR THIS ISSUES
Here comes a new bump. Welcome it.
You haven't heard of me for a long time. Here I am again.
I adore bumps. Unless Intel decides to answer or to create a publicly accessible bugzilla/issue tracker.
Bumping has never been so funny considering no response from Intel whatsoever.
No new working correctly drivers = a new bump.
Here comes a fresh new bump.
Edit: Intel has just released new drivers v14.42.3.64.5268. I'm gonna test them soon. Stay tuned.
Message was edited by: Artem Tashkinov
Get a discrete graphics card and be done with it. Intel HD is for watching movies.
Hello Masoa please tell the corrrect reason for the error(igxprd32 error) its not correct reason to say that to buy the new graphics card and if is not possible the problem is not coming in another motherboard brand and we want the correct reason for this error don't try to hide the reason
Sathis, regardless of the brand of mb intel hd is built on the processor and like the op mentioned it's not for games - more technically it's designed to render 2d graphics. A 3d video card would enable the op to run all the games in question.
I cannot reproduce this issue any longer, the problem seems to be solved. Thank you, Intel.
![](/skins/images/48A1642489FEF8D34D940AC6791CBDC2/responsive_peak/images/icon_anonymous_message.png)
