22655 Diskussionen
a770 card can't display volume/vdb in houdini
noti
Einsteiger
9.675Aufrufe
This problem occurs after updating a certain version (probably 101.4146) of the graphics card driver.
My gpu : Intel® Arc™ A770 Graphics.
Beschriftungen (1)
1 Lösung
Ernesto_C_Intel1
5.466Aufrufe
Hello noti,
Intel has recently released a fix to this issue with the latest graphics driver version:
31.0.101.5522 WHQL Certified (Latest)
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Kindly confirm if the issue still persists after installing the latest graphics driver?
Ernesto C.
Lösung in ursprünglichem Beitrag anzeigen
26 Antworten
Andres_Intel
Mitarbeiter
7.461Aufrufe
Hello noti,
Thank you for posting on the Intel®️ communities. Since you are having issues displaying the volume/vdb in Houdini with your Intel® Arc™ A770 Graphics (16GB). For better comprehension of the circumstances, respond to the following inquiries:
Andres P.
noti
Einsteiger
7.439Aufrufe
Related files have been uploaded
Andres_Intel
Mitarbeiter
7.405Aufrufe
Hello noti,
I have checked on the Intel® SSU that your system is up to date, just to confirm if the driver was properly installed, please answer the question below:
Let me know the results.
Andres P.
noti
Einsteiger
7.370Aufrufe
Andres_Intel
Mitarbeiter
7.361Aufrufe
Hello noti,
Thank you for completing the recommended steps.
I will start with an investigation to provide you with the next steps as soon as possible.
Andres P.
Andres_Intel
Mitarbeiter
7.357Aufrufe
Hello noti,
Thank you for your time.
We would like to try to replicate the issue and to do it as accurately as possible, can you provide us with your project file shown in the previous video to follow the steps properly?
Andres P.
noti
Einsteiger
7.284Aufrufe
It's just a very simple file
Andres_Intel
Mitarbeiter
7.257Aufrufe
Hello noti,
Thank you for providing us with the file.
I will start with an investigation and as soon as I have the results I will let you know.
Andres P.
Andres_Intel
Mitarbeiter
7.045Aufrufe
Hello noti,
Thank you for your patience.
We still working on the investigation and we hope to have the results soon as soon as I have them I will let you know.
Andres P.
Andres_Intel
Mitarbeiter
6.946Aufrufe
Hello noti,
We have been working on the issue reproduction and we hope to have the results soon as soon as I have them I will let you know.
Andres P.
noti
Einsteiger
6.850Aufrufe
Andres_Intel
Mitarbeiter
6.841Aufrufe
Hello noti,
Thank you for your response.
I want to let you know that we are working really hard to try to replicate this issue as soon as possible, as soon as I have the results I will let you know.
Andres P.
Andres_Intel
Mitarbeiter
6.793Aufrufe
Hello noti,
Thank you for all your time.
We have been working on the issue reproduction. The sample file the you shared is not working and does not open. We will need another file that works or perhaps the you can share a video on how to reproduce the issue from the beginning without the need of a sample file.
Andres P.
noti
Einsteiger
6.739Aufrufe
i've uploaded a video:
community.intel.com/t5/Graphics/a770-card-can-t-display-volume-vdb-in-houdini/m-p/1560586#M126998
Andres_Intel
Mitarbeiter
6.724Aufrufe
Hello noti,
Actually I have seen the video you have shared, but the sample file you provided us did not work, so in order to continue with the reproduction, can you provide us another sample file or with a video including the steps on how to create the pig?
Andres P.
noti
Einsteiger
6.713Aufrufe
fine, it's same with a box
Andres_Intel
Mitarbeiter
6.698Aufrufe
Hello noti,
Thank you for sharing the video with the step by step instructions.
Now, I will continue with the issue replication, and as soon as I have the results I will let you know.
Andres P.
Andres_Intel
Mitarbeiter
6.578Aufrufe
Hello noti,
Thank you for all your time and patience.
I know you have shared some videos in order for us to reproduce the issue, we are interested in addressing this issue, however, it would help us if we could get a detailed example of how to reproduce the issue. Perhaps a project we can import and quickly see the issue.
I ran the repro steps on both RTX 4060 and A770 LE and could not observe any difference. See video: https://youtube.com/shorts/rxviEb0Jdt8?feature=share.
Andres P.
noti
Einsteiger
6.570Aufrufe
try to display and check the middle node's output
Andres_Intel
Mitarbeiter
6.437Aufrufe
Hello noti,
Thank you for the recommendation, that will help us a lot.
Remember to provide us with a detailed example of how to reproduce the issue and also a project we can import and quickly see the issue. This will help us to make sure we are following the steps properly.
Andres P.
Antworten
