22657 토론
arc control doesn't install - There is a problem with this Windows Installer package
Radek123
초급자
9,079 조회수
arc control doesn't install - screenshot and log.
Please help.
OPERATING SYSTEM
Microsoft Windows 10 Pro (64-bit)
22H2 (10.0.19045)
Driver bundle Version 31.0.101.4091
Radek
0 포인트
8 응답
Hugo_Intel
직원
9,043 조회수
Hello Radek123
Thank you for posting on the Intel Communities. I am sorry to hear that you are facing issues when trying to install Intel® Arc™ Control on your system. Please let's try the following:
If the issue still persists please create a log file with the Intel® System Support Utility and attach it.
Hugo O.
0 포인트
Radek123
초급자
9,030 조회수
Hello Hugo,
Intel arc control didn't install after clean install.
Please find attached ssu and screenshots.
Radek
0 포인트
Hugo_Intel
직원
9,007 조회수
Hello Radek123
Thank you for sharing this information. Please let's try the following:
1.-Use Display Driver Uninstaller to delete all traces of previous drivers.
2.-Once you complete step 1, download our latest driver that recently came out, version 30.00.101.4123. Make sure that you are running the installer file as Administrator:
  • Right Click on the installer file
  • Run as Administrator
If the issue persists, Could you please let me know if you were able to use Intel® Arc™ Control before? And did the issue happen after a driver update?
Hugo O.
0 포인트
Radek123
초급자
8,986 조회수
Hello Hugo,
Thank you for helping me.
I did DDU intel uninstall and restart in safe mode.
Installed latest beta (your link).
I feel Witcher 3 performance just skyrocketed, CPU dropped, or I'm in some calm field right now.
Intel Arc Controll didn't install.
Other issues I have:
- Monitor connected via HDMI switches off, I must shut it down, turn on again and it works - it's always like that. Minor issue, probably will buy DP to HDMI cable.
Intel Arc Control never install for me. I just bought Intel Arc card so stared with
Radek
0 포인트
Hugo_Intel
직원
8,960 조회수
Hello Radek123
Thank you for sharing these troubleshooting results with us. I will continue checking this issue internally and I will post back once I have an update or in case I need more information from you.
In regard to the issue that involves the HDMI connection, if you happen to continue experiencing the problem after testing a different cable, please open a new thread to prevent confusion in the troubleshooting and get specific steps on that issue.
Hugo O.
0 포인트
Hugo_Intel
직원
8,880 조회수
Hello Radek123
Thank you for your patience. After checking this issue, allow me to tell you that Intel® Arc™ Control does not install on older hardware than 11th-generation processors. In this case, please let's try disabling the iGPU from the device manager:
  • Go to device manager > Display adapters
  • Right-click on Intel(R) HD Graphics 4600.
  • From the drop-down menu click on disable.
  • Restart the system,
  • Try installing the ntel® Arc™ Control.
If the issue persists, please disable the integrated graphics (iGPU) directly from your system's Bios. In case you don't know how to do it, please contact your motherboard manufacturer.
Hugo O.
0 포인트
Hugo_Intel
직원
8,849 조회수
Hello Radek123
I hope you are doing fine.
Hugo O.
0 포인트
Andres_Intel
직원
8,812 조회수
Hello Radek123,
Andres P.
0 포인트
응답
