- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Ссылка скопирована
- « Предыдущий
- 1
- 2
- Следующий »
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AM777, I just received an update on this matter.
There is a new driver available on our official website, version 31.0.101.5186/31.0.101.5234. Please try a clean installation of that driver following the instructions in the links below and once you get the chance, please let us know the results:
Driver:
Albert R.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AM777, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I haven't been able to try your suggestion in detail yet. I will get back as soon as I get a chance to try it.
AM
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AM777, Thank you for your answer.
No problem at all, take your time and once you get the chance, please let us know the results.
Albert R.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Albert,
I was able to reproduce the crash again with the latest drivers that you recommended, so this issue still continues.
AM
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AM777, Thank you very much for your reply.
We are sorry to hear the issue persists. We will continue working on this scenario and provide a response as soon as possible.
Albert R.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
While we are still working on this scenario, could you please try the steps below one by one and note what was the result:
- Turn off cpu virtualization in Bios
- Disabling e-cores
- Disabling multicore rendering in the game settings ==> didn't found this option in game
- System repair
- sfc /scannow
- Dism.exe /online /cleanup-image /restorehealth
- Disable CPU boost in BIOS
- Change SVID to Intel Fail safe in BIOS
Test PC settings in BIOS:
- MCE (enhanced multi-core performance): disabled,
- Active turbo ratios: auto,
- Dynamic Vcore: +0.005V (as per article 000096305),
- XMP: on
- also tested on stock BIOS settings
The game is set to LOW in video settings - no issues ever happen while testing.
List of options that can be used to launch game: https://eloboss.net/blog/csgo-launch-options
Albert R.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AM777,
Albert R.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Albert
I've made halfway through the suggestions:
- Turn off cpu virtualization in Bios - Turned off virtualization / VT-d
- Disabling e-cores - Don't see any such options in BIOS. I have added '-threads 5' to game launch options which seems to have limited game process to P-cores
- System repair - To be tried
- sfc /scannow
- Disable CPU boost in BIOS - No such option in the BIOS
- Change SVID to Intel Fail safe in BIOS - No such option in the BIOS
- XMP: on
Don't see any of the above in BIOS settings
The game is set to LOW in video settings - no issues ever happen while testing - will try with low
Whatever I have tried so far, I still got couple of crashes. I need to try few more of the suggestions, will post another update when I do those.
AM
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I get 70-80 fps
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
With recent game and driver updates, I am no longer seeing crashes as frequently (maybe once in 2 weeks or so).
I believe it was recent game updates that fixed issues for me.
Also on low setting I do get ~50-60 fps at 1080p, this is again an improvement that seems to have come with recent updates. Earlier FPS used to drop to 40 in some situations.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello AM777,
It is great news that the recent updates have enhanced your gaming performance. I wish you a smooth and enjoyable gaming session. As a result, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Norman S.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
- « Предыдущий
- 1
- 2
- Следующий »
