22647 Discussões
i receive 0xC00000E5 error at Intel Iris xe Graphics card
paulmihairusu2023
Principiante
2.976 Visualizações
i receive 0xC00000E5 error at Intel Iris xe Graphics cardscreenshot intel graphichs error 1.jpg
i want to install a intel iris xe graphics 2021 version ! my laptop is
IdeaPad Gaming 3-15IHU6 - Type 82K1
4 Respostas
Hugo_Intel
Funcionário
2.928 Visualizações
Hello paulmihairusu2023
Thank you for posting on the Intel Communities. I am sorry you are experiencing errors when updating your graphics driver.
In order to verify the compatibility and help you with this issue, please share with us the following information:
  • Please share with us the download link where you are getting the driver from.
  • Is there any error message on the driver installer interface?
  • Create a log file with the Intel® System Support Utility and attach it to your response for more information on the hardware configuration.
Hugo O.
Hugo_Intel
Funcionário
2.909 Visualizações
I hope you are doing fine.
Hugo O.
Hugo_Intel
Funcionário
2.873 Visualizações
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
Access-Violation
Principiante
1.796 Visualizações
Hello support,
this issue is very urgent - please propose a fix:
Application is using Directx9 (Winamp 5.92 running the Visualization plugin Milkdrop 2.25d).
Application crashes only with Intel Iris Xe Graphis driver (its running fine with Radeon Graphics driver or Intel UHD Graphics 600 31.0.101.2115 driver on a second computer)
Error Messsage of Winamp applikcation is attached.
Intel Support Utility Log is attached as well
Please fix this fast - it is very annoying!!
Responder
