Intel® ARC™ Graphics
2173 Discussions
新驱动降屏幕刷新率
zz18
自32.0.101.5768版本后,我的显示器就从165hz降到120hz了 锁在最高120hz 什么时候能处理??我现在都不能升级 升级就只能用120hz 赶紧处理吧 大哥 我想更新都不行 赶紧处理!!
DeancR_Intel
Hi zz18,
请注意,我只能用英语为您提供支持。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译。
Thank you for posting in the Community!
Please make sure you provide the following basic information when reporting a bug:
  1. What is the graphics driver you are using?
  • Confirm you are using the latest WHQL graphics driver available (let us know the exact driver version you are using).
  • A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
  • You could also test using the latest non-WHQL driver. This driver goes through all Intel quality assurance processes and is safe to use for evaluation.
To better understand your system's configuration, I kindly request that you download the Intel® System Support Utility for Windows* software.
You can find the download link here:
  1. Download and launch SSU.exe.
  2. Check the box for "Everything."
  • When the scanning is complete, click "Next."
  • Click "Save."
  • Please send the saved file to us.
Dean R.
zz18
感谢你的回复,驱动从32.0.101.5768以后,我的显示器就从165hz下降到120hz。您也可以查看我附加的截图,附加文件《11》是您要求的 希望能够尽快修复bug 感谢!
zz18
DeancR_Intel
Hi zz18,
I suggest trying the following steps here:
Unable to Select the Native Resolution and Other Supported Refresh...
Let me know if the issue still persists.
Dean R.
zz18
尝试了,还是不行。从最新驱动降回101.5768就又可以了,我想这应该是驱动的问题。
DeancR_Intel
Hi zz18,
This is an acknowledgement message for your inquiry, do please wait as this will be investigated internally to be able to provide a resolution to your request. I will get back to you once I have the necessary information.
Dean R.
DeancR_Intel
Hi zz18,
I would like to know the exact model of your monitor that encountered the issue.
Dean R.
zz18
DeancR_Intel
Hi zz18,
Thank you for this information, I will investigate this internally and get back to your once I have the necessary information.
Dean R.
DeancR_Intel
Hi zz18,
I suggest trying the steps below and let me know the outcome:
1. Perform a DDU (Display Driver Uninstaller) How to Use the Display Driver Uninstaller (DDU) to Uninstall an....
2. Install graphics driver version 32.0.101.6325_101.6253: Intel® Arc™ & Iris® Xe Graphics - Windows*
3. If the issue persists, I would like to know if you are using a DisplayPort or HDMI connection.
4. I would like to clarify as well if you are using a direct video cable connection, such as HDMI to HDMI or DP to DP.
Dean R.
